Issue with Clutch Pedal, GT2 MOD HELP!
Old Feb 8, 2018 | 09:30 AM
craigtl35's Avatar
craigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to behold
Just had motor out to do injectors and now installer is having difficulty getting the clutch pedal to return to the top position sporadically(First pump it does not come up, if you pump it a few times it will return to normal) . He has bled the clutch fluid 3x with no change. I do have the GT2 slave cyl mod and Sachs 2.5 clutch installed (Which I have had 2 + years with no problems) the pedal was working perfectly fine before we dropped the motor.
Suggestions? Ideas?
Old Feb 8, 2018 | 10:15 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Every time you pump the pedal and it returns to normal position check the fluid, it is likely low. If so then top up the fluid and pump the pedal another 50 times and recheck the level. Keep repeating until there is no more loss of fluid.
VID997
Sep 24, 2018 03:08 PM
magoochi
Nov 27, 2016 10:30 PM
crash41301
Sep 1, 2015 08:49 PM
AlanS
Jul 11, 2008 10:18 AM
