Help: BBI Clutch Slave Conversion Kit
Good morning, all dimensions are a close apx. as the spring is housed in a casing and I don't want to remove it.
OD 1.069" (27.15 mm)
ID .790" ( 20.07 mm)
L 2.500" ( 63.51mm)
Hope this helps you out.
Regards
L 2.500" ( 63.51mm)
Regards
Thanks!
Wonder if you can get a higher spring rate so it "helps" you out a little more:
https://www.mcmaster.com/9620K41
https://www.mcmaster.com/9620K31
Thanks!
Regards
This is helpful, would have been nice to have this info before I "sprung" for the cost of a complete unit as I could have just replaced the spring alone for a lot less money. Anyhow, replacing the stock clutch assist assy because of little to no resistance. Will look into different springs if I the stock gt3 unit too stiff. Let me know if you have any luck in the spring department :-)
Regards
Regards
