SAI Pump connector
Old Apr 23, 2019 | 03:42 PM
RickRST's Avatar
RickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to all
SAI Pump connector
Where is this located please? Mine is coded out and it just makes unneeded noise on cold startups!
Thanks.
Old Apr 23, 2019 | 03:47 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
What sort of noises?
Old Apr 24, 2019 | 07:27 AM
Thanks.
on 997TT the SAI pump is on the driver side all the way in the back behind the inlet pipe, its black, cant miss it.
#TeamAIM
Old Apr 25, 2019 | 08:19 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
It shouldn't make noise as it should be muffled by the air box. If it makes noise then the plastic tube that goes from the back of the airbox to the pump is disconnected or cracked.
Mine was cracked and on startup sounded like a jet engine for a bit.
Old Apr 25, 2019 | 12:59 PM
RickRST's Avatar
I am referring to the combustion note change when air is being injected, not the actual pump noise.
VAGscum
May 14, 2017 10:17 PM
DOPE_996tt
Mar 26, 2017 05:42 PM
Mad Ness
Feb 11, 2014 01:40 PM
FAST FWD
Aug 20, 2010 11:31 AM
