997.1 TT with AASCO Flywheel - Do I need a harmonic damper?
Old Sep 13, 2019 | 04:00 AM
BillyBawb's Avatar
BillyBawb is infamous around these partsBillyBawb is infamous around these parts
As the topic states - I'm running a 997.1 Turbo Cabrio Manual with 28k miles on the clock - It's now running a Stage 3 FBO setup, with an AASCO lightweight single mass flywheel + Sachs 2.5 spec clutch, and quite happily spins past 7k RPM
Question being, how soon (if at all) should I look at fitting a harmonic damper? It makes sense getting one, especially considering the amount of chatter one hears at idle and low RPM - but I guess I'm just trying to get a gauge for how much of an issue harmonics actually are on a TT engine?
Given the chatter at lower RPM, and a rev ceiling of 7500 RPM, is the motor really at risk of backing out cam bolts / pulley bolts / flywheel bolts / cam actuators / breaking oil pump gears / shearing the pin & mangling the stock pulley?
I've found the Dundon item, which is basically just a rebranded ATI Super Damper... https://www.dundonmotorsports.com/996-997gt3-harmonic-dampe?carid=123 - It seems to be the go-to solution.
Advice / input / examples of failures would be greatly appreciated.
TIA gents.
Old Sep 20, 2019 | 09:34 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Great question, I would love to get some professional perspectives on this.
Old Sep 30, 2019 | 12:14 PM
mikestyle's Avatar
Anyone?!
Old Mar 16, 2026 | 07:07 PM
THEMASH's Avatar
THEMASH is infamous around these parts
No one has any experience with this ? i am considering a light flywheel as well. Would love some feedback.
Old Apr 13, 2026 | 03:52 AM
Ruskiy's Avatar
5 Year Member
Ruskiy is a jewel in the roughRuskiy is a jewel in the roughRuskiy is a jewel in the rough
If Fluidamper made one for our cars, that would’ve been heavenly.
The rubber band style ones like ACT (Dundan) are wearable items unfortunately and targets select rpm unlike Fluidamper which covers multiple frequencies it seems with zero service ever needed.
Old May 28, 2026 | 04:13 PM
supra.z06's Avatar
supra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant future
Don’t do it, stick to the oem one - listen to the expert:
View this post on Instagram
bsh
Apr 20, 2018 12:27 AM
austx911
Feb 24, 2017 09:49 AM
TurboKC
911
Oct 5, 2016 02:10 AM
reisskhan
Oct 31, 2014 12:22 PM
Slick997
Apr 20, 2012 07:04 PM
