upgrading the turbo crankshaft during a build..
Hola! I am pre gaming on my build and I was wondering if anyone had the part number for the crankshaft that is considered the upgrade to our stock crankshaft. Is it the GT3 or GT3RS crank that has the smaller but wider diameter connecting rod journals? I want to make sure I order the right one as the builder will only install a new one. Does anyone have a part number?
What the frick is that cam shaft for?
Anyway here is some reading for you:
https://performancedevelopments.com/...-rod-bearings/
A billet crank from EVOMS:
http://www.evoms.com/EVOMS_Lightweig...engcnccrnk.htm
Doing a quick look through, many builds do not reference cranks, though it seems that your horsepower goal would be indicative of whether or not that component should be looked at.
Ed
Ed
Ed
Ed
Yeah the Performance Developments article is what I read, and why I want to use this part. Sadly it does not not mention part numbers. Apparently the crank is OEM and about half price that of the billet crankshafts offered by EVOMS and other builders. I am not building a HP queen, but I understand the mechanics behind the larger surface area for the oil film provided by this crank swap. In the end it will be peace of mind and added reliability (in my opinion).
The GT3 KAT says:
97.76 engine:
2 numbers:
996 102 021 93
996 102 021 94
97.77 another version of the GT3 - maybe later build?)
996 102 021 95
and
97.74 The RS 4 liter engine
997 102 021 8B
Ed
97.76 engine:
2 numbers:
996 102 021 93
996 102 021 94
996 102 021 95
and
997 102 021 8B
Ed
Cool....looks like up to 99610202196 now.
SHANKENFELTER
Jan 8, 2008 05:20 PM
