997 Turbo MK2 indicator front bumper
Old Jul 15, 2017 | 01:32 PM
Stroker's Avatar
Stroker is infamous around these parts
Hi guys,
some month ago I updated my 997.1 MK with the 997.2 Turbo front bumper and use the lower light as a daydrive light as well as the LEDs inside the indicator.
I still have the problem with a failure message in the dash about the front indicator and the inside indicator signal is flashing faster but the outside is flashing normal.
I think this was done several times before but I can't find an answer in the search function.
Would be nice to get some help.
All the best
David
Old Jul 16, 2017 | 01:22 PM
Stroker's Avatar
Nobody knows a solution?
Old Oct 12, 2019 | 05:53 AM
Miao's Avatar
Miao is infamous around these parts
i have the same issue!!!
Old Oct 12, 2019 | 05:35 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
I'm going through the same issue but on the rear end conversion to 997.2. Hopefully, you have a 2007 or 2008 car with that front control module 997 610 104 11. If so FVD makes a controller that is just plug and play . Otherwise you need to buy the 2009 control module 997 618 513 01 and have some pins changed for LED and DRL's. I watched my tech pull off the sleeve connectors that lock the harness into the control module. There is a blue and a black one. He then was able to show me where the Pin changes happen. It's crazy. Hopefully you can avoid all that and just go with the FVD controllers.
Currently I have the fast indicator on my dash and normal up front like you said. I also am getting warnings on my dash. I take my car in on Tuesday and hopefully will be corrected. Good Luck!
Old Oct 18, 2019 | 09:17 AM
Miao's Avatar
add a 25w resistant and it will work fine!
NunyaBiz
Merchandise For Sale / Wanted
Aug 31, 2015 11:39 AM
BlackPepper
Cayenne 958
Feb 12, 2012 12:58 AM
Abdon
Jan 13, 2012 06:26 AM
