Front Lower control arm torque ?
Old Oct 23, 2019 | 02:31 PM
GazC2's Avatar
5 Year Member
GazC2 is infamous around these parts
can anyone tell me the torque setting for the front lower control arm to the body which I loosened off to fit my springs , I believe the suspension has to be loaded up before you tighten , also the drop links as well
Old Oct 23, 2019 | 09:11 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
From the WM4001TW manual:
Threaded
connection, cross
member with
diagonal arm to body
(front) M 14 x 1.5
Please note:
Do not
grease
threaded
connection in
Dacromet
finish –
aluminium
colour.
Tightening
torque
160 Nm (118 ftlb.)
There is no mention of pre-weighting the suspension for this, but the WM401819 says to use a new locknut.
The drop links from WM400119 says:
Fit connecting link on anti-roll bar.
Fit connecting link -1- on anti-roll bar and screw on and tighten
nut -2- .
 Three-stage tightening procedure (1st stage: tighten to 50
Nm (37 ftlb.). 2nd stage: loosen by 90 degrees. 3rd stage:
tighten to 65 Nm (48 ftlb.).: 65 Nm (48 ftlb.)
Also nothing mentioned about pre-weighting the bar, but I normally do this with the suspension by manually positioning by using jack stands and measurements from the center of the wheel to the fender. That way there is no preload on the bar. I don't think there is much of an effect on the front diagonal but I do the same thing on almost every suspension bolt I install.
Ed
Old Oct 24, 2019 | 11:00 AM
GazC2's Avatar
5 Year Member
Threaded
connection, cross
member with
(front) M 14 x 1.5
Please note:
Do not
grease
threaded
connection in
Dacromet
finish –
aluminium
colour.
Tightening
torque
160 Nm (118 ftlb.)
nut -2- .
Ed
Ed
Thanks for that in regards the suspension being under load before tightening the nut I can see the sense in this because when you slacken it the arm drops and like your suggestion my intention was to compress it with the trolley jack then tighten the nut
Cheers
Gary
Old Oct 24, 2019 | 04:46 PM
lliejk's Avatar
5 Year Member
Just make sure both sides are up when you do that, use a jack stand on one.
Ed
gclasse
Aug 26, 2019 01:57 PM
turboslut
Aug 18, 2019 10:01 PM
ciaka
May 2, 2018 05:16 PM
MrChan
Jun 13, 2012 08:23 PM
VAGscum
Jul 20, 2011 08:38 PM
