TPMS Replacement
Old Apr 9, 2021 | 12:13 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
TPMS Replacement
Guys-Car is 10 Years Old and I'll be replacing the tires. I was told that our Tire Pressure Monitor Sensors need to be replaced as there is no battery that is serviceable. Is this true?
Is this an item that we can get an as good an aftermarket TPMS a Porsche OEM part elsewhere?
Mine are working fine, but as long as the tires are off and the car is a decade old I'm thinking its time.
Any advice ?
Old Apr 10, 2021 | 07:29 PM
IXXITT's Avatar
IXXITT is infamous around these parts
I do not believe you can replace the battery alone, and they last 7-10 years from what I remember. Each unit is about $80-100 depending on the frequency required (FCP Euro TPMS). Huf is a good brand and most likely OE. What I linked is what I'll go with when the time is right.
A good diagnostic scanner can tell you remaining battery life and frequency, also needed to reset TPMS.
Old Apr 11, 2021 | 04:17 AM
Jim f's Avatar
Jim f is infamous around these parts
There are a couple tpms vendors online. I bought the OEM equivalent for a little over $200 for 4.
Old Apr 11, 2021 | 06:29 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
For TPMS either get them from FCP Euro, lifetime warranty or TireRack. I have tried both and both have excellent brands that have lasted 9 years on one car and 5 on the other.
Old Apr 11, 2021 | 06:40 AM
GT3Fan24's Avatar
GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !
Any advice ?
Correct you cannot replace the batteries. Yes you can get an OEM equivalent and for that car it is a Huf (BHSens) RDE001. Same sensor used for OE just won't pay the Porsche tax. I have bought from here.
https://www.tpmsbargains.com/PORSCHE...PMS-s/1370.htm
No such thing as a lifetime warranty on TPMS. The batteries will eventually go and no company is going to replace your TPMS when the batteries wear out. Most manufacturer warranty for 1-2 yrs. Manufacturers will say TPMS will last 5-7 yrs. I have seen them last less (a lot of miles) and plenty last very long especially on cars that are not driven much as they will go into "sleep mode" when inactive for some time.
Old Apr 11, 2021 | 03:06 PM
IXXITT's Avatar
Based on your comment, I'll safely assume you haven't purchased from FCP Euro. They lifetime warranty all their products (including oil, brakes, etc.) as part of their business model. Try them, you'll convert...
Old Apr 13, 2021 | 05:18 AM
GT3Fan24's Avatar
I see now. Not a bad business model. Charge 2x (on some TPMS 3x) the other guys charge, offer a lifetime replacement and chances of car folks keeping their cars 10+ years, remembering to save documentation and actually using the lifetime warranty is probably minimal. It must work or they would not be in business just swapping out used brake pads all day long.
Old Apr 21, 2021 | 08:03 AM
metaphysician's Avatar
5 Year Member
metaphysician is infamous around these parts
I highly recommend TPMS.com. I picked up Huf Intellisens when I swapped my wheels/tires. They came pre-programmed and ready to go. No issues so far.
Old Apr 21, 2021 | 12:16 PM
JSF721's Avatar
What year and exact model and spec is your car.
id love to order plug and play tpms sensors.
Old Apr 21, 2021 | 12:30 PM
5 Year Member
2011 Turbo. Not sure what year/model your car is, but select here: https://www.tpms.com/Porsche-TPMS-s/1860.htm
This is what I bought Huf Intellisens (OEM supplier): https://www.tpms.com/Porsche-911-Tur...11turbo997.htm
I had my wheel/tire guy mount these when putting new tires on and they worked out of the box without a dealer needing to program them further. They will automatically sync with the reader on your car once you start driving.
Old Apr 21, 2021 | 01:58 PM
GT3Fan24's Avatar
They will come programmed and ready to install. Your car is then auto relearn so you do not need a tool to do the relearn.
“5%off” works at www.tpmsbargains.com even cheaper than the other place, same sensor.
Old Apr 22, 2021 | 07:57 AM
512bb's Avatar
Keywords in my post were "FCP Euro".
Old Apr 24, 2021 | 01:10 PM
997ttLevel3FVD's Avatar
997ttLevel3FVD is infamous around these parts
I just had these installed with with my new tires on my new OZ Ultraleggera wheels. 2007 Turbo. They paired up on their own in about 5 minutes. I was very happy with the price.
Old Apr 27, 2021 | 03:27 PM
Edgemonty007's Avatar
Edgemonty007 has a spectacular aura aboutEdgemonty007 has a spectacular aura about
I just had this happen. Went with the HUF RDE001 99760602102. $59.98 each. 433mhz worked perfect.
Old Apr 28, 2021 | 08:08 AM
JSF721's Avatar
Do the Huf OEM sensors just re learn or do you need to prompt them in the PCM-If so what is the process please.
