Spacer solution for unique lug bolts
Old May 16, 2021 | 02:47 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
My 20" wheels have a narrow bolt hole for the mounting bolts with an allen head. I use spacers for my 19" wheels with longer bolts to compensate. I need spacers for the wheels pictured but I have not idea where to source these lug bolts in a longer size. The spacers that bolt to the hub and then use the original lug bolts for the wheels would solve my problem if I could find a set that were 12-15mm wide but I haven't found any spacers under 17mm wide that can bolt to the hub and use the original lug bolts for the wheel.
Any idea where to find either 10mm longer lug bolts like the ones pictured or a bolt on spacer that is 12mm wide that will allow me to use the narrow bolts that work with these wheels?
Last edited by mrmaass; May 16, 2021 at 02:52 PM. Reason: clarification of problem
wattsci
Jan 7, 2015 07:53 PM
viprklr
Track & Autocross
May 5, 2014 06:52 PM
BLKPPR
Feb 25, 2013 12:53 PM
delirium
Jan 14, 2011 11:51 PM
ClayMan
Wheels/Tires
May 12, 2008 09:35 AM
