Help!!!!
Old Aug 30, 2021 | 03:46 PM
Lazu's Avatar
Lazu is infamous around these parts
Help!!!!
I always look at my dash lights and just noticed this. Car has never over heated. Is it normal or should I check out something specific.first pic light is on second off. Continuous blinking.
Old Aug 30, 2021 | 08:37 PM
IXXITT's Avatar
IXXITT is infamous around these parts
Check your coolant level asap & report back. Could also be engine compartment fan or coolant sensor. Scan for codes.
Old Aug 30, 2021 | 08:58 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
With engine compartment fan failure,it will also tell you that ,mine just started acting up & shop is telling me that means it's usually a vacuum leak or a thermostat.
Old Aug 31, 2021 | 08:21 AM
Lazu's Avatar
Ok my fan was removed to fit a gt2 wing that I will be installing. I turn the car on and realized that I hadn’t put the fan back so I immediately turned off the car and installed fan. light was still blinking. I will check coolant level. Thanks for all.
montreal911
Sep 4, 2012 11:24 AM
mptoledo
Jun 30, 2009 09:47 PM
rzundel
Jan 23, 2007 11:17 AM
