Starter cable replacement?
Old Mar 12, 2023 | 05:12 AM
GazC2's Avatar
5 Year Member
GazC2 is infamous around these parts
Can anyone point me to a thread on replacing the starter cable, I am having hot start issues at the moment I replaced the starter a couple of years ago so making the assumption it's time to change the cable, I have read threads on a carrera S but not a Turbo.
Any wisdom appreciated
Gaz
Old Jun 25, 2023 | 04:04 AM
jon_d_h's Avatar
jon_d_h is infamous around these parts
Gaz
hi mate, you ever get to the bottom of this? Got the same thing with my 997 turbo. Thanks
Old Jul 17, 2023 | 08:49 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
The ground cable on the driver side is usually the one that goes bad, bust so does the power distribution block if it never had the TSB done.
997-607-034-04 - ground (engine to chassis)
997-612-908-00 -power pin repair kit
Old Jul 18, 2023 | 02:32 AM
GazC2's Avatar
5 Year Member
I ended up changing the starter motor which fixed the problem
Coloradocurt
Dec 11, 2015 08:40 PM
Cali_997
Apr 25, 2014 10:24 AM
louie007
Jun 13, 2012 07:41 PM
911 Molar
Feb 18, 2011 06:13 PM
