tire pressure sensor
Old Aug 4, 2006 | 11:01 PM
997hk's Avatar
997hk is infamous around these parts
Question tire pressure sensor
Anyone know if we can use the original tire pressure sensor and mount on the new wheels in order to keep the tire pressure monitor? or we have to get a new set of sensor for new tires?
Old Aug 6, 2006 | 11:55 AM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
You can use the ones from the stock wheels.....but, you have to break down the wheels to get the sensors...I bought new sensors, but, with aftermarket wheels, banding seems like a terrible solution...My sensors have fallen off my aftermarket wheels and are rolling inside the wheels...TPMS sucks!
Lou
Old Aug 6, 2006 | 12:03 PM
997hk's Avatar
so how u manage to fix finally?
Old Aug 6, 2006 | 12:16 PM
LSM's Avatar
LSM
Senior Member
They're not fixed, still rolling around inside my tires...Waiting for HRE to give me a solution
Lou
Old Aug 6, 2006 | 12:22 PM
damon@tirerack's Avatar
Moderator
TPMS doesn't suck Lou. It saves lives. You just have to install the sensor in the wheel correctly. Using a band to strap a sensor intended to be put through the hole is an ***-backwards way to do it on a several thousand dollar wheelset. If you have a valve based sensor, buy a wheel that will allow it to fit into the hole correctly or take your business elsewhere. I warned you Lou, and look what you got as a result.
Good luck with HRE - there isn't a solution. The barrel section of the wheel has the wrong angle so it will never work. And you now see just how "well" the bands work.
If your stock sensors wouldn't have fit in your new wheels, I certainly hope HRE told you before you dropped all that cash.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 6, 2006 | 12:30 PM
Moderator
997hk - just ask the seller of the wheels before you buy them, they should (hopefully) know.
damon@tirerack.com
Or use this link:
Old Aug 6, 2006 | 04:45 PM
drbf's Avatar
drbf is infamous around these parts
When I changed from stock C4S wheels to Carrera Sport Wheels the sensors were changed over without any problems.
RallyBird
Oct 7, 2015 01:20 PM
PenguiN
Sep 15, 2015 11:44 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
