Engine problem
Old Feb 20, 2007 | 11:51 PM
2K7997TT's Avatar
2K7997TT is a jewel in the rough2K7997TT is a jewel in the rough2K7997TT is a jewel in the rough
Let's gather ourselves here.....
You are upset that your 140K car is not functioning...
You are upset that you have had to pay top dollar to get your car towed...
You are upset that you recently paid top dollar for an exhaust...
Perhaps the installer loosened a hose or a clamp.
In no way, is the exhaust to blame. The exhaust just can't cause the symptoms you are describing.
I feel for you. And I will read all of your posts of lament and frustration.
Old Feb 21, 2007 | 12:00 AM
gmoney's Avatar
1. Check all exhaust connections / bolts etc.
2. Check all hoses.
Also, what EXACTLY was replaced exhaust wise? And who installed it?
Your first call should be to the installer AFTER you have inspected visually everything yourself. More times than not the issue is a simple fix.
Like a few have noted, I'd wager a hose popped off based on the sound of things.
Old Feb 21, 2007 | 01:58 PM
TT Surgeon's Avatar
Sounds like a hose loosened up, no fault of the exhaust, rather the installer. Should be simply remedied by the installer without involving the dealer. But if you do go that route, do return it to stock.
Old Feb 22, 2007 | 12:31 AM
lamvince's Avatar
lamvince is infamous around these partslamvince is infamous around these parts
Why would a hose be lose. I had it done at a muffler shop, and I personally checked the exhaust before the guy put the car down. everything was screwed in correctly.
Old Feb 22, 2007 | 12:44 AM
Byronmaui's Avatar
Byronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to behold
Lam easily you could have a hose loose by the installer of the mufflers. Listen to these guys because they know their stuff.
Byron
Old Feb 22, 2007 | 03:31 PM
lamvince's Avatar
Whatever happened has already happened. Lets hear what the service people have to say
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
