Modification Issues
Old May 24, 2007 | 03:56 PM
Alfred Dunhill's Avatar
Alfred Dunhill is infamous around these parts
Modification Issues
Hi guys, i have installed the fabspeed maxflo exhaust + racing cats along with EVOMS headers 3 days ago, from the moment i drove the car with all these mods on, i have noticed an excessive heating issue, before installing the exhaust setup, i raced a friend he also has a 997 turbo and we raced like 5-6 times in a row with sport mode on etc, the engine heat level sat exactely on 90 after those 5-6 runs, now i just drive from my house to my friend's which is like 3-4kms and its above 90... is this normal or is there something wrong??
One more thing, in my previous M5's the E39 and E60, after installing after market exhausts i feel the power right away, for some reason i dont feel that much of a diff in the turbo, does it take time? or is this it?
Old May 24, 2007 | 03:59 PM
msindi's Avatar
you need an ECU remap ideally...
Old May 24, 2007 | 04:00 PM
I already have a GIAC software installed...
Old May 24, 2007 | 04:16 PM
fredttx50's Avatar
fredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond repute
did you have software put on after new mods, or before.
If before, like Msindi said, you need to remap.
GL.
Old May 24, 2007 | 04:17 PM
I had it installed before but i think it was mapped for this set up
Old May 24, 2007 | 04:57 PM
JamE55's Avatar
JamE55 is infamous around these parts
Try remapping it again and drive xxx miles to adapt.
Old May 24, 2007 | 06:02 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
disconnect the battery for 30 min or so and restart. That should clear out some of the fuel trim adaptation
Old May 24, 2007 | 08:49 PM
PorschePhd's Avatar
This is not enough data to tell me anything. What EXACT numbers are you seeing. Log it with a data logger so we know. Engine oil temp, engine collant temp is not an issue unless in the red! The EGTs will drop 120 Degree C with what you have. That is better than factory. Many factors can cause engine oil temp and collant temp to go up. It is not a worry unless it is near the red marks which indicates an issue of some sort. That does not seme to be the case here. Enjoy the car!
Old May 24, 2007 | 08:54 PM
TT Surgeon's Avatar
The ecu map is the culprit, as Stephen said, you need more info and if anything should be running cooler.
Old May 24, 2007 | 11:58 PM
The indicator on the far left, engine oil, it heats up so quick without me hammering it or anything
Old May 25, 2007 | 08:01 AM
03-turbo911's Avatar
Senior Member
It's supposed to be hovering around the 90's when normal. When it passes 120 and stays there is when you should be worrying.
COBB Tuning
Jan 1, 2025 09:02 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
