H+R Spacers
Old Sep 13, 2007 | 09:51 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
H+R Spacers
Has anyone experienced strange handling after fitting the 7mm and 15mm spacers?
Did you have to use longer bolts even for the 7mm spacers?
Thanks.
Old Sep 14, 2007 | 01:58 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
My TT is running some 15mm H&R spacers and I don't found any strange handling issue. My other car running 5mm H&R spacer and they come with longer bolts.
Old Sep 14, 2007 | 02:22 AM
firas_997's Avatar
firas_997 is infamous around these parts
no problem with spacers at all , and you need longer bolts which should come together with the spacer set . it better looking car with spacers go ahead .
Old Sep 14, 2007 | 02:41 AM
raffi's Avatar
raffi is infamous around these parts
i have heard that you do not need longer bolts with the 7mm, but i use them.
the 5mm porsche spacers even come with longer bolts...
someone had posted a technique to install the spacers to make sure the bolts are seated correctly. the original poster was having the same handling issue i believe
Old Sep 14, 2007 | 08:53 AM
damon@tirerack's Avatar
Moderator
VERY WRONG INFORMATION! DON'T DO IT! YOU HAVE TO ADD LONGER BOLTS IF YOU ADD SPACERS!
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Sep 14, 2007 | 08:59 AM
raffi's Avatar
hey damon, i thought it was odd too, but i have read this from a few different vendors on the boards...
Old Sep 14, 2007 | 09:33 AM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
ADD THE BOLTS - NO QUESTION!
50/51mm for the 7mm FRONTS. - Ball Seat!!
Boldgt
Mar 23, 2016 11:07 AM
djhill
Oct 29, 2015 07:04 PM
DYL 911
Oct 1, 2015 02:47 PM
Pcar991
Sep 29, 2015 05:20 AM
