Engine Washing
Old Dec 24, 2007 | 06:52 PM
Samy's Avatar
Samy is infamous around these parts
Engine Washing
Hy guys, i want to ask your advice. I keep washing my engine quite often because it gets dirty very quick and i rarely use any kind of wash aid on it,just plain water. Anywai i now noticed that there is a squecking sound in the engine compartiment when the car is not reved and it seems to come from the belt of the engine. I read in the user manual that it is good to wash the engine but apply a engine protection solution or something like that. What is this,where can i find this product? About the squecking i guess there is a special spray i can use to lube the belt but i also don't know wich product to use. Can you give me some advice to how to maintain my engine compartment in top condition......
Old Dec 24, 2007 | 07:25 PM
rah79's Avatar
rah79 is infamous around these parts
Do first and ask later? Seeing that you already have been doing this I hope you have been covering the electrical wiring and components, distributor before you start. Then use a engine degreaser to spray the engine. Then just use a hose to wash it off. You should be able to find more detailed info on the net....its PITA as its been awhile since I've done this.
As per the engine did you take it to the dealer? Seems as though you still have warranty since its an '07
Good luck
Old Dec 25, 2007 | 11:35 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
I have been washing my engine in all my cars for well over 30 years. the one thing I have found to really help out is I wash the engine when it is hot. Then after washing I crank it up and let it run. I also use a battery powered leaf blower to dry it. Between the heat and blower I have never had any problems. I also make sure water does not get down the air intake.
Old Dec 25, 2007 | 12:19 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
Good luck
Rah don't worry about a distributor...most modern cars have do not have a distributor anymore. I would worry somewhat of some of the connections even though they are meant to be "weather" proof. I just wouldn't be using ultra-high pressure on connections..just enough pressure to rinse off not to penetrate.
Dave
Old Dec 25, 2007 | 12:27 PM
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
I've always been told the engine should be warm vs. hot as not to crack the block etc. I've also found that if you don't let the dirt accumulate for too long it comes off with a mild degreaser soultion sprayed onto a rag and nothing stronger is really needed.
Old Dec 26, 2007 | 07:07 AM
cvazquez's Avatar
cvazquez is infamous around these parts
IMO- Simple Green is biodegradable and works well for engine and under carriage cleaning. Do not use strong chemicals on paint, rubber and, plastic parts. Engine degreasers are too harsh of a chemical for the P-car engine compartment.
Old Dec 26, 2007 | 07:48 AM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Just spray the engine like you would the body of the car. In 40 years of doing so, I have yet to have a problem. Obviously, drive the car for a while afterwards to dry the engine and componants.
Old Dec 29, 2007 | 06:16 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
I just wipe it down, no washing, I don't go-off roading nor drive it in the rain a little dirt/dust won't hurt the looks of the engine.
Old Dec 29, 2007 | 07:22 PM
DrPeter's Avatar
DrPeter has a spectacular aura aboutDrPeter has a spectacular aura aboutDrPeter has a spectacular aura about
If the belt is squeeking, it may need to be tightened. It is not a loss of lubrication problem.
Old Dec 30, 2007 | 07:59 PM
scuzy's Avatar
scuzy is infamous around these parts
So you would just cover the air intake with a rubber glove and jsut spray the engine compartment with water and a little msimple green and dry it ?
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
away
Sep 4, 2015 12:30 PM
Gewgaw
Aug 19, 2015 11:52 PM
