Check engine light ( 997 C4S )
Old Jan 22, 2008 | 01:36 AM
mishref's Avatar
mishref is infamous around these parts
Originally Posted by Floppy
Hi Raja,
How behaves the tool while running on battery mode (Laptop) ?
Has this been an issue? ...
I personally had no issues flashing the car or using the Durametric on Battery Powered. I had my laptop power configuration set to maximum performance.
Old Jan 22, 2008 | 05:40 AM
Floppy's Avatar
Floppy is infamous around these parts
Mishref, if it isn't set to maximum performance you might run into issues which can cause an error message simply due to the fact that the default setting might not allow to run all the features with your .NET Framework as well as shutting down some additional features which might slow down the performance of your laptop. In some cases it is even possible that the software won't even work. That is why we always recommend to connect the Power Supply.
Thanks, Flo
COBB Tuning
Jan 1, 2025 09:02 AM
vr6tee
Aug 29, 2015 03:52 AM
cab83_750
Aug 19, 2015 12:37 PM
