Changing battery
Old Mar 8, 2008 | 06:07 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Changing battery
For almost 3 weeks I have noticed that my car ( the C2S) does not start regularly.It takes like 2-3 sec's. I can feel the ignition rotates slower than what it should. I’m 90% sure that battery needs to be changed.
Right now I’m shipping my car to California for an exotic cars run so I don’t have time to take it to the dealer. My questions are Can I change the battery by myself? What kind of battery should I buy?
Thank you
Old Mar 8, 2008 | 06:12 PM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
easy to change. get one that fits.
Old Mar 8, 2008 | 06:14 PM
Do i need to reprogram the car ? I was thinking of starting the engin and change the battery while it's running to avoid any kind of fults
Old Mar 8, 2008 | 06:21 PM
lardog's Avatar
I hope your kidding. JUST change the battery with the engine off. Why would you get a fault?
Old Mar 8, 2008 | 06:54 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
I understand your concern, as I had a similar one when I disconnected my battery to install a new steering wheel recently. Given the complexity of the PCM etc, I was concerned that loss of voltage would trigger weird faults etc. However, disconnection does not do anything other than cause the PSM to recalibrate itself for the first minute or so after re-connecting. You simply drive the car and it re-sets. It is covered in the manual, but it was a no-brainer. In the case of my cab, and I expect the coupe is the same, you may need to put the windows down and up so that the car can re-learn where the up position is. Again, a no brainer.
Old Mar 8, 2008 | 11:08 PM
mishref's Avatar
mishref is infamous around these parts
I would not change the battery while the car is running .. I have swapped batteries a couple of times and its very simple. A couple of things to keep in mind when you swap batteries (when the car is off):
You will get a pasm/psm failure which will reset a couple km after driving. You also need to reset your window height (I think you will need to push up for 5 seconds). Its quite easy to do and listed out in the manual.
Old Mar 8, 2008 | 11:18 PM
Thanks Khaled and kenin. I'll change it as soon as I get there.
Old Mar 8, 2008 | 11:19 PM
ty328's Avatar
ty328 is a splendid one to beholdty328 is a splendid one to beholdty328 is a splendid one to beholdty328 is a splendid one to beholdty328 is a splendid one to beholdty328 is a splendid one to beholdty328 is a splendid one to behold
Don't do that! Make sure you order the right battery & have the right tools to changer that battery. You don't need to reprogram your car again, if so just go buy another P-car. Just kidding!
Old Mar 9, 2008 | 12:30 AM
axhoaxho's Avatar
axhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud of
Don't just unplug the old battery and plug in the new battery.
Get one of those 'car battery power station' from Sears or Target, about $50.
Plug it into the 12V cigarette lighter adapter in the cabin, and then disconnect the old battery. This way we won't need to reprogram the radio, etc. Put in and connect the new battery, and then disconnect the power station.
I have done it in my Boxster S, and it worked well.
With best regards,
- Alex; 07 997S, 00 986S, 87 951.
Old Mar 9, 2008 | 09:09 AM
NorthVan's Avatar
Buy the Porsche Battery Maintainer, I plug mine almost every weekend. Once a week, it only requires an over night charge. Plugs into the cigarette/accesory plug.
Old Mar 9, 2008 | 09:18 AM
lardog's Avatar
+1 on the battery charger. I use a battery tender.
COBB Tuning
Mar 29, 2016 09:26 PM
away
Sep 4, 2015 12:30 PM
00aston
Aug 27, 2015 12:01 AM
DSCOFF
Aug 23, 2015 01:22 PM
