Brakes Conversions
Old Apr 1, 2008 | 10:54 PM
Turbo S's Avatar
Turbo S is infamous around these parts
Brakes Conversions
Hi,has anyone done a brake conversion from a 997 Carrera S' Red brake kit to a Carrera's?Can this be done and what it takes to do the conversion.Grateful for advices,thanks!
Old Apr 1, 2008 | 11:05 PM
08-911-C4S's Avatar
08-911-C4S is infamous around these parts
I do not know what is required for the Carrera red "S" brakes to be fitted to the non Carrera "S" models. However, I do know that the Boxster and Cayman red "S" brakes are a direct bolt-on fit to the base Carrera model using existing rotors and pads. This will not add any performance gains just the bling!
Good luck,
Ken
Old Apr 2, 2008 | 12:19 AM
Turbo S's Avatar
Good luck,
Ken
The Carrera S brakes has got much better heat tolerance and does not fade even 40laps.As i have just done the Porsche Advance Drivers Training in Australia.The thickness of the rotors are much thicker than the std Carrera blacks...which started loosing grips after abt 20 laps..
Old Apr 5, 2008 | 12:40 PM
MichaelL's Avatar
MichaelL is infamous around these partsMichaelL is infamous around these parts
The 997S brakes are essentially equivalent to the brakes in the 996 turbo.
Old Apr 5, 2008 | 03:58 PM
Antz_997s's Avatar
Antz_997s is infamous around these parts
Yes it is possible but not worth the cost. I would opt for the PCCB brakes instead if you're tracking your car.
Off topic: Turbo S, is that your car in your avatar? I think i've seen your car at Tanglin area before..
Old Apr 5, 2008 | 06:06 PM
FLYN-LOW's Avatar
FLYN-LOW is infamous around these parts
You will need to change out the wheel carriers. The standard carrera wheel carriers will not work with the "S" brake kit. The 997S can be upgraded to the turbo/gt3 brake kit without replacing the carriers.
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Lamborghini Vendor Classifieds
ModBargains
Maserati Vendor Classifieds
Oct 13, 2015 03:46 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
