Leaking oil from the front of car, Help!
Old May 4, 2008 | 05:00 PM
b911s's Avatar
b911s is infamous around these parts
Put about 70 miles on the car today. Drove to a freinds house about 35 miles then back. He called me after i got home and said there was oil all over his driveway. I immediatley checked myself and sure enough a small puddle under car back here at home. Jacked the car up and oil dripped from the front opening in the belly pan where the differential opening is. Checked the oil level looks like i'm down 1/2 quart according to the dash display. Anyone ever had this problem and or any recommendations. Was going to jack the car up and drop the front cover and see if i can find maybe a loose fitting. This sucks, only 300 miles on the car. Any off the top of your head suggestions would be appreciated, if not, calling Porsche first thing in the AM.
Old May 4, 2008 | 05:31 PM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
bring it back to the AD.
Old May 4, 2008 | 08:09 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Is it leaking from the center differential? or near a wheel. I think the differential is above the bottom "cover" on the car, so you may have to remove it to see the source of the leak. If it is near a wheel it could be a shock leaking.
Old May 4, 2008 | 08:29 PM
b911s's Avatar
Couldnt tell where is was coming from so I took it to the dealer. Let them fix it.
Old May 4, 2008 | 09:05 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Good thinking here! Please post findings. Tx. Gerry
Old May 5, 2008 | 01:42 AM
yrralis1's Avatar
If this leak is coming from the front of the car my guess is that it's the front differential . I hope I am not correct .
Good luck . Keep us posted .
Old May 5, 2008 | 06:21 AM
Michael2364's Avatar
Michael2364 is infamous around these parts
I think there is an engine oil cooler up there also.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Enemy
Nov 10, 2015 08:01 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
