Help with 6 sp Manual trans oil change
Old May 9, 2008 | 06:51 PM
vrnkc's Avatar
vrnkc is infamous around these parts
2005 997 6 speed manual. I just drained 3 liters of manual trans oil. I put in 3 liters of new trans oil. Yet, this was not enough oil volume because there was zero excess oil coming out of the fill hole. When I put my finger in the fill hole, I could not feel any oil. So the question is: should I continue to add more oil until the excess spills out or leave everything alone? Note: the owner's manual states the oil capacity to be 2.9 liters.
Old May 9, 2008 | 07:38 PM
MartinJF's Avatar
MartinJF is infamous around these parts
I looked on RENNTECH you have to fill to the bottom of the oil fill hole.
If you removed 2.9 quarts and filled with 3.0 quarts then you were probably a little low, just add a little more.n Capacities are approximate.
Here is the RENNTECH tread.
http://www.renntech.org/forums/index.php?showtopic=7060
It is for a Boxster but it probably okay, call the dealer and see if you can talk to a tech.
Old May 11, 2008 | 09:51 AM
vrnkc's Avatar
my mistake
My mistake: I was refilling the oil into the wrong filler hole! There are actually two holes for filling: one high up on the housing and one placed lower on the housing. I mistakenly used the high one.
COBB Tuning
Jan 1, 2025 09:02 AM
pshep138
Sep 1, 2015 09:45 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
