Knocking sound in front with pss10 damptronics, any suggestions?
Old Jul 14, 2008 | 09:16 PM
b911s's Avatar
b911s is infamous around these parts
Knocking sound in front with pss10 damptronics, any suggestions? (UPDATED)
I have developed a knock in the front when going over bumps that unweight the car a little. I have checked all the suspension components and the only thing i can figure is that when this does happen the springs seperate from the top spring seat and then hit when coming back down causing the noise. This didnt happen when they were first installed and seems to be getting worse. Any suggestion from you guys that have these or anyone would be appreciated. It is starting to drive me a little nuts.
Bruce
Old Jul 14, 2008 | 09:58 PM
NorthVan's Avatar
Bruce,
I had a noise in my suspension when it was first installed and it only occured at low speeds (while parking) and with the wheels turned. I took it back to the shop that installed them, they too checked everything, but it was still there. I decided to drive it a while and the noise has gone away. Your problem sounds weird, the only way to unsettle your suspension enough to get total seperation would be to jump a creek like the Dukes of Hazzard use to do! I would suggest calling Bilstien technical support and perhaps they have heard of this problem before. I would love to know what the source of this noise is.
Ed
Old Jul 15, 2008 | 03:08 AM
Ian_UK1's Avatar
Ian_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to behold
Bruce
This sort of knocking - over bumps - is usually associated with wear in the strut-top bearings. They're partly made of plastic and tend to fail, especially when more highly loaded by stiffer than standard dampers. Thankfully they're an inexpensive part - spring compressors are required to fit them so it's usually a workshop job but not a major one.
Old Jul 15, 2008 | 03:12 AM
jiaim's Avatar
jiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to all
reuse your big stock factory top silentblock instead of the ones provided with the bilsteins.
Old Jul 15, 2008 | 11:48 AM
b911s's Avatar
Thanks Ian, this makes sense because that was the only so called loose part in the setup. Actually when i got the shocks I had a problem from the start and they were stuck in sport mode which is extreamly stiff. It was driven this way for probobly 600-700 miles here on our rough PA roads until we figured out one of the shocks had a short in it and it blew out the PASM control module. When this happened they all defaulted to stiff mode. I will call and get new strut top bearings and see if that does the trick.
Bruce
Old Jul 15, 2008 | 12:09 PM
surfingbuddhist's Avatar
surfingbuddhist has a spectacular aura aboutsurfingbuddhist has a spectacular aura about
I have the same knock from my newly installed Damptronics too. Please keep us posted if that fix works. Thanks.
Old Jul 15, 2008 | 12:46 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
I have Damptronics as well, but do not have a knock. Would like to know what is causing the problem though. I installed them myself so if I ever develop the problem it would be nice to know what it could be. I hope you guys find the solution.
Old Jul 29, 2008 | 12:42 PM
b911s's Avatar
A trip to the dealer revealed that my lower sway bar link was loose. They tightened it up and the car is perfect, no knocking at all.
Old Jul 29, 2008 | 01:10 PM
Thanks for the update. I'll check that out, but haven't heard the knock since the first day....
Old Jul 29, 2008 | 04:03 PM
NorthVan's Avatar
Glad to hear it wasn't anything serious.
Old Jul 29, 2008 | 06:48 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
Good tip- thanks
Old Aug 1, 2008 | 08:36 AM
p0rsch3's Avatar
Just to confirm jiaim's post, is it possible to use the factory Porche top hats instad of the Bilstein hats?
Old Aug 1, 2008 | 08:50 AM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
I ended using the stock Porsche top hats per eclou's recommendation. Great stuff on this post with pictures and all:
https://www.6speedonline.com/forums/...tallation.html
Old Aug 1, 2008 | 08:53 AM
spyder997s's Avatar
Bruce, happy to hear that it was a minor issue and that the car is ok. BTW, your car looks great! Very nicely done: great wheel combination with the color. Stay wingless and save money!
Old Aug 1, 2008 | 10:19 AM
BoostJunkie's Avatar
BoostJunkie is infamous around these parts
This happened to me too, apparently the nuts on the swaybar endlinks that Bilstein supplies tend to loosen up when the wheel is turned all the way to full lock.
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
vr6tee
Aug 29, 2015 03:52 AM
Zero911
Aug 24, 2015 06:51 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
