GT front bumper grin-vent install on regular 997 front bumper...
Old Aug 29, 2008 | 05:38 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
^^ My source for mesh: www.afterhoursautomotive.com - call and talk to Brian, he stocks it for use on track cars. he used the 1/8" square weave on my top vents and 1/4" weave on the front radiator openings. The stuff does not dent, it gives and springs back.
Razor knife- "Utility Knife" - Home Depot, metal handle with a slide-forward slanted razor blade.
Old Aug 29, 2008 | 05:58 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
i like the black diamond shapped grilles myself. its what GMG and Cargraphic uses. but, then again, im biased btw, there's a thread about the grilles here.
Old Aug 29, 2008 | 06:02 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
I'm looking for suppliers of the various meshes (diamond, square, hex, round, etc)... there has to be a metal supplier to get them from.. trying to avoid the inevitably marked up sheets from an auto customize shop.
Old Aug 30, 2008 | 08:01 AM
candyman168's Avatar
candyman168 is infamous around these parts
I did the cut out for the grill on my stock S bumper, cutting the bumper was not difficult but the problem I encountered was the grill did not sit flat on the S bumper maybe because there is slight difference with the shape of the S bumper compared to the Gt3 bumper. Or just maybe there were nowhere to screw the grill onto. We had to hold it down with silicone, lots of it!
It looked ok after that. But eventually I went for the Gt3 bumper when Suncoast lowered the price.
Old Aug 31, 2008 | 02:08 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Do you have pic of the GT3 vent on your stock S bumper?
Old Aug 31, 2008 | 03:13 AM
Minok's Avatar
Is it possible to mode the GT bumper to eliminate the lower ground clearance and get it back to the height of the stock 997 bumper by removing the lower trim? For me its an issue of not wanting the bumper any closer to the ground.
The support issue could be solved by adding the necessary support for the vent under the bumper, or using the 'clips' described in the linked Cayman threads earlier.
Old Aug 31, 2008 | 07:31 AM
Sorry I didnt take a photo of it before I switched to the Gt3 bumper, it wasnt photo worthy!
Its all boxed up in my storage already.
Old Sep 11, 2008 | 01:02 PM
Minok's Avatar
Does anyone have a picture of the inside of the GT3 bumper where I could see how the vent attaches to the GT3 bumper?
Is it a frame that is integral to the bumper cover, or is it a separate part?
Old Sep 11, 2008 | 01:29 PM
i'll check my pictures when i get home
Old Sep 11, 2008 | 03:17 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Does anyone know if it is possible to remove the black plastic piece on the factory aerokit that covers the area where the the GT3 third radiator vent's normally. I wanted to place screens on the openings but thought it would look better if the screens were placed in all three openings instead of just the side radiator vents.
Old Sep 11, 2008 | 03:20 PM
yes... you can just replace it with the piece the GT3 has
GT3 retaining frame center 997.505.541.01
the standard 997 has 997.505.541.00
Old Sep 11, 2008 | 03:32 PM
///MJFDDS's Avatar
Sweet, Thanks Fern. Then can I head up north so you can install some screens for me?
Old Sep 11, 2008 | 03:40 PM
///MJFDDS's Avatar
Where is the best place to order this part?
sure let me know when. also, i have a set of side screens already made and glued to the housings. just need to swap housings off your GT3 bumper. the center grilles just sandwich together. no glue required.
Old Sep 11, 2008 | 03:45 PM
///MJFDDS's Avatar
I am interested. Let me know how much? Will save me some time from having to form the outer ones myself.
Matt
