Advice: Should I get an oil change
Old Nov 25, 2008 | 10:44 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
Ok I have heard different stories from different mechanics.. so I'm calling for some 6speed knowledge.
My car (997 S) had an oil change 3,600 miles ago.
Since that oil change I have done about 6 autocrosses and 3 full days at the track (80+ miles each day).
My dealer says I don't need an oil change.
My porsche mechanic says I do, as I should change my oil after every 2-3 track days.
Another porsche mechanic told me I don't need one for at least another 2,000-3,000 miles.
WHAT DO YOU THINK???
Old Nov 25, 2008 | 11:10 PM
yrralis1's Avatar
The opinions will vary on this . Some will opt for the long interval of the manual (particularly those who lease ) while others change frequently .
I have followed the same regimen with all of my Porsches of "one year or 7500 miles whichever comes first" .
Old Nov 26, 2008 | 06:47 AM
NorthVan's Avatar
I did 13 DE's (about 2000 miles in total) and I am one a one a year for my oil changes. This is based on the advice of both my local dealer as well as the independent that does all the service on my car.
Old Nov 26, 2008 | 08:53 AM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Everyone is different but I change mine every 2 track days. The oil stays at high temperature for a long time on the track.
Old Nov 26, 2008 | 09:46 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
whats the big deal, its not like its that expensive, if your on the fence on changing or not....just change it, it can only be better, it cant hurt
Old Nov 26, 2008 | 12:34 PM
Lostturbo's Avatar
Lostturbo has a spectacular aura aboutLostturbo has a spectacular aura about
+1
Old Nov 26, 2008 | 06:31 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
I think I read in either Excellence or GTPorsche that the oil should be changed after each track day just to be safe.
Jason
Old Nov 26, 2008 | 06:40 PM
MelsM3's Avatar
MelsM3 is infamous around these parts
If you do ALL maintenance according to the Porsche manual AND you have everything documented, you will be fine.
Old Nov 27, 2008 | 11:18 AM
Da Hapa's Avatar
Da Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of lightDa Hapa is a glorious beacon of light
Exactly. Spend the $180 and call it peace of mind.
Old Nov 28, 2008 | 03:51 PM
schicago's Avatar
schicago is infamous around these parts
I change the oil before storing the car for winter, after the 2 last DE's.
Old Nov 28, 2008 | 06:32 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
It all depends on the oil temps you had on track/autox days... I think that a well driven street car (no track) should change oil every 6000 miles (or 1 year). Tracked cars much more often - in some cases even after each track day. You will hear that oil lasts much longer, yadadyada... I used to change non-synthetics at 3000 miles, so now I double it with synthetics.
Some argue that an oil change is expensive. It does not have to be... it's a DIY task.
Old Nov 28, 2008 | 09:01 PM
bbywu's Avatar
+1
Oil change is pretty easy. DIY, save money, and have piece of mind all at once.
Old Nov 29, 2008 | 07:30 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Not to throw your world into a spin... but.... are you going to use 0w-40 or 5w-40 Mobil 1...or another brand.
Old Dec 2, 2008 | 01:05 PM
mobonic's Avatar
Mobil 1 0W-40
Old Dec 3, 2008 | 01:35 AM
cephas's Avatar
cephas is infamous around these parts
people said the original oil come from the factory is special and only for break in.
So, change it earlier than you should is worst than keeping it after 10k.
Anyway, I changed mine at 4k.
