key in hand, car still running
Old Mar 2, 2009 | 01:10 PM
nosubt2's Avatar
nosubt2 is infamous around these parts
I just got a 06 S last month. Sunday on the way to an autox, I stopped for gas. Turned the car off and got out with my key in hand. The car was still running. Dealer says they have never heard of this problem. Anyone have this problem??
Mark
Old Mar 2, 2009 | 01:32 PM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
what happened next?
Kerrigan Smith's Avatar
Kerrigan Smith has a spectacular aura aboutKerrigan Smith has a spectacular aura aboutKerrigan Smith has a spectacular aura about
The car was obviously bought used, but was it from a certified dealer? And yes I would say this is very strange if not almost freakish.
Old Mar 2, 2009 | 01:33 PM
Nitro911s's Avatar
Nitro911s is infamous around these parts
did u turn the key all the way off before you pulled it out?
Old Mar 2, 2009 | 01:41 PM
raffi's Avatar
raffi is infamous around these parts
Originally Posted by tejoe
what happened next?
it drove back home 500 miles to find its original owner since it missed him so much...
never heard of this before either, did it turn off by itself or did u put the key back in ignition? so wierd
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Mark
Very odd indeed. Ignition switch broken? Or some electrical mod gone awry. Otherwise, I don't see how the engine could run without electricity to the ignition system with normal gasoline engines.
Old Mar 2, 2009 | 01:50 PM
MishaDesigns's Avatar
hmm very odd
Old Mar 2, 2009 | 01:54 PM
NorthVan's Avatar
I would take it to the dealer and let them fix it.
That is the weirdest thing I have heard of.
Old Mar 2, 2009 | 02:00 PM
ak996TT's Avatar
ak996TT is infamous around these parts
Wink
Did you have a autostarter? I beleive this is one of the function you can do with the autostarter. You can still take the key out while the engine is running ...Just like a turbo timer sort of things...cooling down the oil in the turbo while you park and go with the key.
anymods you didn't know from a previous owner??
Old Mar 2, 2009 | 03:34 PM
nosubt2's Avatar
After i noticed the car was still running, I just put the key back in the lock and turned it off again. This time it worked.
Old Mar 2, 2009 | 03:53 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
Sounds the lock itself might be a little loose. My old M3 has this issue. If I dont press the key in nice and tight it will turn but without actually doing anything. Sounds like the same thing is happening to you. However, I am surprised the car would run with the key fully removed.....hmmm
Jason
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
