Whining sound coming from engine area while driving..???
Old Jun 4, 2009 | 01:33 AM
Shant's Avatar
Shant is infamous around these parts
Hi,
In the past 10 days or so, I've noticed a slight but definitely noticeable high pitch "whizzing" sound coming from the engine area. My car is a 2007 997 C4S, tiptronic.
The sound is apparent only while driving at speeds 40mph+. The high pitch sound is independent of the engine noise (ex. I can put the car into neutral driving while driving at 65 mph and the pitch of the noise will not change at all). However, the pitch of the noise will get higher/lower relative to speed of the car. Tires are proper pressure, lots of tread remaining.
I need to educate myself before taking it to the dealer. Any ideas? Belts, intake, fluids, etc.
Thanks.
Shant
Old Jun 4, 2009 | 07:10 AM
NorthVan's Avatar
Are your windows open? It could be coming from your outside mirrors, it has been a problem in the past, but I thought they fixed it.
Just a thought.
Old Jun 4, 2009 | 11:14 AM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
I've had the "same" problem on and off for 5 months on an 06; particularly when I lift off the gas to slow down - a noticeable (to me) whine that I thought was maybe coming from the tranny. Had my good indie drive it and he said he did not feel/hear anything bad.
Hope we get a good and cheap answer.
Old Jun 4, 2009 | 11:36 AM
RSSsales's Avatar
RSSsales is infamous around these parts
Take a look at your belts. Might be a belt is getting worn.
Ben
Old Jun 4, 2009 | 05:40 PM
nugent_crai's Avatar
nugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud of
i installed a new intake and the whine from that is INSANE! I dont know if your talking belt whine or intake type whine, but maybe the intake???? If you let off the throttle and keep it in N and its steady after a good distance, rule out the intake, but if you put it in N and its variable, its probably something else.
Old Jun 14, 2009 | 04:18 PM
Shant's Avatar
Still cant figure this problem out. I need to take it in to the dealer for inspection.
Anyone else have any ideas?
Old Jun 14, 2009 | 05:53 PM
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
Altenator whine?
turbotuner20v
Sep 11, 2015 12:02 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
