997 Cab rear window cleaning tip
Old Jul 6, 2009 | 11:08 AM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
This may be a well known thing, but I've not seen it posted so I thought I'd offer it up. Standard caveat: I am not a Porsche certified mechanic and take no responsibility for any damages or warranty violations that may come from this procedure. Proceed at your own risk.
When I first got my 997S Cab, I found it incredibly hard to do a good job of cleaning the inside of the rear window. It's a long reach and I didn't much like kneeling on the rear seats.
When I installed my SmartTop, it required unclipping the rear soft top and it turned out to be remarkably simple. In addition to enabling the installation, I realized it was the perfect technique to access the rear window. You'll also likely find that there is an amazing amount of detritus that accumulates in the cowl-covered section. It's mostly flotsam and jetsam that falls off of the top when it's being retracted. I vacuum out the boot area whenever I clean the window. Yes, it's OCD-theatre, but I suspect I'm not alone!
1. Start the opening sequence of the soft top, but stop it (just hit the switch or switch off the ignition) when the retractable cowl is furthest open;
2. If you look in where the cowl normally is, you'll find that the rear of the soft top is secured by two wire cables that fit over two ***** (one on each side). You may have to fish around in there to find them as they are covered by a vinyl flap;
3. Simply reach in and unclip the swaged cable connector from the **** in the rear section. It takes a bit of tugging, but it's a plastic or nylon pressure fitting and it slips off with no risk of damage;
4. Once you have both cables unclipped, you can simply lift up the rear of the soft top and expose the inside of the rear window;
5. Reverse the procedure to re-assemble the soft top.
Here are some photos:
Old Jul 6, 2009 | 11:09 AM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
yep- that is the way to do it, it's very easy. Thx for taking time to document and post pics!
Old Jul 6, 2009 | 02:26 PM
Gundo's Avatar
Gundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud of
Do it the same way - thanks for taking the time to document! Rep power to you!
Old Jul 6, 2009 | 09:45 PM
maozisky's Avatar
maozisky is infamous around these parts
thanks for sharing!!!
Old Jul 6, 2009 | 09:47 PM
djantlive's Avatar
Good tip for those with older 996 that has plastic windows.
Mackchacha
Jul 9, 2019 11:03 AM
r_matt_6
Oct 8, 2015 06:07 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
roncooper
Aug 19, 2015 01:17 PM
