Help please Carrera S tips on Carrera
Old Aug 5, 2009 | 07:04 PM
lakercarrera's Avatar
lakercarrera is infamous around these parts
I have some Carrera S tips I want to put on my carrera but the S is a bigger diameter, is there any shims I can use or any helpful tips? thanks
Old Aug 5, 2009 | 07:22 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Any good shop should be able to fabricate a sleeve that will fit between the two, allowing you to fit them on appropriately.
If you can't find such a shop, even a PepBoys will sell an adapter, which will fit snug over your outlet pipes and be larger diameter on the other end, allowing you to clamp the tips tightly. The only adjustment you may need to make is to cut a bit off the larger diameter end of the adapter to ensure that the tips don't stick out too far.
CATTMAN
Old Aug 5, 2009 | 09:41 PM
vrnkc's Avatar
vrnkc is infamous around these parts
Harbor Freight Tools have an expander tool to widen the exhaust pipe. I think it is about $10.
Old Aug 6, 2009 | 06:57 AM
Cattman's Avatar
Yes, and also any decent muffler shop should be able to do pipe fitting, to expand the outlet pipes, although that's permanent, whereas a sleeve between the outlet pipe and S-tips is easily reversible.
CATTMAN
Old Aug 6, 2009 | 10:51 AM
grr none of my local autozones/pepboys have an adapter i think i may have to go to an exhaust shop
bzimpfer
Sep 26, 2015 10:55 PM
VGLNTE1
Sep 8, 2015 12:42 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
