Question about Cab Side Window
Old Oct 13, 2009 | 09:17 PM
patrija's Avatar
patrija is infamous around these parts
Hi. I have a question regarding the side windows in my '07 C4S Cab. I'm familiar with the side windows' slight drop when opening to door. What I find "odd" is that when I get into the car by myself, occassionaly when I turn the ignition key I can hear passenger window adjust slightly. It only seems to be the passenger window and only if someone has not open/closed the passenger door. But it's not all the time. Any insight?
Old Oct 13, 2009 | 11:27 PM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Unlock your car - Both windows drop ~ 1/8 in.
Open a door - that window drops ~1/2 in. to clear the rubber molding.
Close the door - that window fully closes.
Start the car - any window on a door that was not opened/entered/closed now fully closes (this is typically the passenger window when you are alone).
Why - who knows? Some engineer at PAG maybe.
Old Oct 14, 2009 | 07:35 AM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
My guess would be allow the air to escape,so you can close the door gently instead of needing to slam it shut....!
But this is a guess at best!
Stacy
Old Oct 14, 2009 | 11:56 AM
PersianGodFatha's Avatar
PersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of light
Intresting, I knew the window on the open door comes down a bit, but didnt know they both drop when you unlock the car
Old Oct 14, 2009 | 12:46 PM
patrija's Avatar
Thanks! I was only familiar with the windows going down slightly when opening a door and then back up when closing it.
Crazy engineering ... of course I remember dreading my first car that had basic power windows as being "another electrical gimmick that will break"
Old Oct 14, 2009 | 12:50 PM
stevepow's Avatar
OK now, be careful not to jinx yourslelf.
Old Oct 15, 2009 | 08:38 PM
mshanler's Avatar
mshanler has a spectacular aura aboutmshanler has a spectacular aura aboutmshanler has a spectacular aura about
I think the window features are pretty neat...but if there is an intermittance...it might be a sensor of some sort.
I had a loose inside doorhandle (driver's side) which affected the sensor on the window (05 cab S): When I would close the door..sometimes it would seal completely against the cabrio top...and sometimes it wouldn't. I also noticed it would move a little (also intermittantly) when I put the key in the ignition.
When I had the inside doorhandle replaced, the intermittant window problem went away.
The P-service guy told me he's seen this on a few 997's...He suggested it might be an issue where people 'overuse' or abuse the doorhandles with that double-action to unlock, then get out of the car. After paying for a new doorhandle, I'm already in the habit of using the center lock button.
Jul 29, 2019 11:13 AM
Sep 1, 2015 03:16 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 19, 2015 06:55 PM
