Wheel alignment - Full tank of gas ?
I don't need to do this, but I had a 964 '90 and I read Adrian Streather's bible about this car
I remember he recommended making the wheel alignment with a full tank of gas
And if you are more **** (
) then do the alignment with you sitting inside the car (if most of the time the car is driven only with you inside it)
Your thoughts ?
) then do the alignment with you sitting inside the car (if most of the time the car is driven only with you inside it)Your thoughts ?
We perform the allignment full tank but only ballast the drivers side if performing a corner ballance.
Your thoughts ?
if you are not going to corner balance first don't worry about driver weight...anywhere between a half and full tank will be fine
For cars with normal shocks/springs suspension setup just somewhere between half and full tank of gas and ready to go, correct ?
BlackMarketRacing
Dec 8, 2015 01:49 PM
r_matt_6
Oct 8, 2015 06:07 PM
WheelB
Lamborghini
Aug 20, 2015 12:25 PM
