Oil level said too low?
Old Nov 9, 2009 | 12:20 PM
ess04's Avatar
ess04 is infamous around these parts
Thanks for the help. This is my first Porsche...it sure is thirsty, but I'd say it's a small price to pay for the incredible driving experience.
Old Nov 9, 2009 | 12:22 PM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
oil
FWIW, not advice, just to confuse you more:
My 2006S, flashed, etc., generally Florida car
1) My tuner/maintainer ( part time Rolex driver, former Porsche tech now with his own shop) checks bars after an oil change and 10 minute drive; gets it at the mid point - once he drained out 2 cups since it was at the top.
2) Blasphemy, I know, but he uses 15W-50 on almost all of the Porsches he takes care of. Main difference from 0W-40 is much higher viscosity at startup (131 vs. 78 at 40C) and a little higher at operating temp (18 vs. 14 at 100C). I would not agree with him on this if it were a Northern car, but after the break in a few years ago I've never had to add a drop between changes.
Mobil does not make 0W-50 and 5W-50 is hard to get, otherwise I'd guess he would use it but I never asked.
Old Nov 9, 2009 | 01:45 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
rvhpno80 reps added.... thanks for the info.... i love detail info....
Old Nov 10, 2009 | 02:14 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Originally Posted by rvhpno80
This happened to me yesterday, and i put 2 quarts in, and it was fine. I want to know, If i just got a oil change from the dealer about 3 & a 1/2 months later the oil is low, what is that from? I have did it about 4 thousand miles ago, Do I need another oil change?
You don't need an oil change.. why would you think you needed an oil change? What you needed was more oil. With the acceptable oil consumption rate being as high as a quart in about 750 miles, you can go 4,000 miles and burn a few quarts and that is within operational parameters. Just add oil.
But just add the needed amount. Don't go dumping in quarts ***** nilly.. follow the instructions. Probably 1/2 quart at a time, if the light came on for low oil, then when you start seeing bars on the meter ... add 1/4 quart at a time until you get in the middle of the range at least and then stop. (Of course on HORIZONTAL (not same as flat) ground).
Or is it because i drive fast and hard, not abusive though but a little more then the average speed limit 110-150 mph, every so often.
A little more than the average speed limit? Really? I'd not say that driving 2x+ the posted limit is a little more but way over. 80-90 is a little more.
Old Nov 10, 2009 | 07:02 PM
rvhpno80's Avatar
thanks i appreciate that, rep points added....
Old Nov 10, 2009 | 08:43 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
It takes almost an hour on a 997.2 to get all the oil out even when hot. It is real easy to overfill the engine, especially if you go by capacity instead of by the measurment.
Old Nov 10, 2009 | 09:36 PM
porschedds's Avatar
porschedds is a splendid one to beholdporschedds is a splendid one to beholdporschedds is a splendid one to beholdporschedds is a splendid one to beholdporschedds is a splendid one to beholdporschedds is a splendid one to behold
To add some more insight, I noticed I went through oil more when I moved down south from the mid-atlantic area. (summer move) Anyhow my oil read low, and I added a half quart, let it run through and settle and gave it another read. Ultimately I need the whole quart!
To me 2 whole quarts is alot being from NY? Since you got an oil change anyhow, see what happens over the course of a few months. Did you take note of how much oil the dealer needed to replace? Also are you running sport mode all the time?
Old Nov 11, 2009 | 12:17 AM
rvhpno80's Avatar
not all the time but alot...
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
riverflyer
Sep 1, 2015 04:22 PM
tkebp1275
Aug 31, 2015 06:35 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
