Oil level said too low?
Old Nov 5, 2009 | 07:09 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
This happened to me yesterday, and i put 2 quarts in, and it was fine. I want to know, If i just got a oil change from the dealer about 3 & a 1/2 months later the oil is low, what is that from? I have did it about 4 thousand miles ago, Do I need another oil change? Or is it because i drive fast and hard, not abusive though but a little more then the average speed limit 110-150 mph, every so often. Let's say once to twice a week, this is my weekend car, not a DD.
P.S the dealership said every 10,000 miles on synthetic, is that true or should i schedule a appointment asap. Thanks for all feedback. I need your help on this one guys....
Old Nov 5, 2009 | 07:21 PM
yrralis1's Avatar
I would be careful not to overfill it . I usually add a quart . I've done it twice in 2300 miles . In contrast my 997tt has yet to take oil and I do change it every 5K miles.
Old Nov 5, 2009 | 07:28 PM
rvhpno80's Avatar
okay thanks yrralis, so this seems to be a little normal, it didnt go over the top bar line.... it seems normal now.... but you have me a little nervous now....
Old Nov 5, 2009 | 07:35 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
I seriously doubt you needed 2 quarts... I suspect people overfill these engines all the time. Do take several oil measurements at different times on level ground with engine at op temp before adding oil.
Old Nov 5, 2009 | 07:44 PM
rvhpno80's Avatar
damn...... guys you are scaring me, I'm just going to get another oil change, i rather spend another 150, then spending 16,000 on a engine that porsche wont cover because I over filled it.... thanks i appreciate all feedback, i will take it in tomorrow, they will let me skip, i have a great rapport with them.
Old Nov 5, 2009 | 10:32 PM
adias's Avatar
That may be overkill, but if you do it... do make sure they do not overfill it either.
Old Nov 5, 2009 | 11:51 PM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
No need to hit the top line either when topping it off - I shoot for somewhere in the middle - if I get to 1 bar down, that's enough. It's a "range" not a point. You can always add a little more later.
Old Nov 6, 2009 | 12:52 AM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
i needed 1.5 qts when light came on.. i see light. add 1 qt..
then i drive and recheck and try and keep it like 2/3rd in between the bars..
Old Nov 6, 2009 | 08:29 AM
GOOGc4s's Avatar
GOOGc4s is infamous around these parts
FYI .....one bar down from top bar equates to half a quart of oil. If you put TWO quarts in you have definetly overfilled the case. Take to dealer immediatley
Old Nov 6, 2009 | 08:32 AM
rvhpno80's Avatar
no thats is where it is at now, one bar below that line, and again i appreciate all this feedback, you guys are the best...
Old Nov 9, 2009 | 10:17 AM
ess04's Avatar
ess04 is infamous around these parts
oil issues
I have an 09 C2 6spd. I live in Miami and it has been hot. I only have 2600 miles on it and this is the second time my oil level warning has been triggered. The first time this happened I called a local dealer to ask what oil they recommend and the service desk said 0w40. I then called the dealer I purchased the vehicle from and they replied 0w50, and that is what I went with. This time I checked out the Mobile site and it said 0w40. I'm not sure what to do, but I only want the best for my baby. Any help would be appreciated.
Old Nov 9, 2009 | 10:26 AM
adias's Avatar
Your dealer misspoke. It's either Mobil 1 0W40 or 5W50. Go with the factory fill - 0W40.
Old Nov 9, 2009 | 10:28 AM
rvhpno80's Avatar
thanks for all the help, its in the middle now.... where it is suppose to be, but is this normal guys.....
Old Nov 9, 2009 | 10:52 AM
adias's Avatar
Watch it every couple of days (more often if you drive 100s of miles/day). If it drops near the bottom, add 1/2qt and keep checking. Do however multiple measurements, on level surface with the engine idling at op temp.
Old Nov 9, 2009 | 10:53 AM
rvhpno80's Avatar
Cool
cool....
