TPM/ Loose Nut / Pressure issue 997.2
Old Mar 27, 2010 | 05:03 PM
Scott997's Avatar
Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !
This is the 2nd time this has happened to me. The outer nut that holds valvestem (& tpm) has worked its way loose.
The first time scared the hell out of me because I lost all of my pressure at once and needed to get towed because I didn't know what it was. Obviously the tire would not hold any pressure.
This time I just noticed after getting my rear tires changed my one side was loosing pressure slowly. I was scared I had a bent wheel, but just realized that damn nut was so loose I could tighten it down with my hand.
I'm really aggravated, and don't want to tighten the nut too tight from the outside.
Has anyone had this problem before?
I was thinking of using the blue loctite on the nut. Does anyone know the torque spec? Is this a good idea?
Old Mar 27, 2010 | 05:30 PM
machina's Avatar
machina has a spectacular aura aboutmachina has a spectacular aura about
This happened to me a few weeks ago and i posted about it.
I was able to get home before the pressure dropped to low.
The torque setting is 4 Nm or about 35 in lbs
Old Mar 27, 2010 | 05:36 PM
p-cardriver's Avatar
p-cardriver is infamous around these parts
Here's what I would do:
1. clean the threads on both parts with something that will remove any grease, oils, wax, etc.
2. reassemble to the correct torque as above.
3. apply a small dab of paint or nail polish across the nut and onto the threads. If this paint seal is broken, the nut is moving.
4. if the paint seal breaks, use some loktite. Continue to use a paint seal as an indicator until you are confident the problem is resolved.
Old Mar 27, 2010 | 06:44 PM
Scott997's Avatar
Thank you so much guys. I'm glad I wasn't the only one. I appreciate the torque specs and the nail polish is a great idea, so I can visually inspect. Thanks again. have a great weekend. I feel a lot better now.
PenguiN
Sep 15, 2015 11:44 AM
LiquidElephant
Aug 27, 2015 06:17 PM
Zero911
Aug 24, 2015 06:51 PM
metzkaro
Aug 24, 2015 02:59 PM
