key range, lock beep, pedal placement questions
Old Jun 6, 2010 | 03:09 PM
jhbrennan's Avatar
Originally Posted by gloves
Yes I have known about holding the remote up to your temple for years, and it really does work but I gain maybe 10 extra feet. Looks like I will look into the battery. Thanks for all the help with the SmartTop stuff, I assumed maybe the dealer could do it but if not oh well.
As far as the pedals go, I am just doing it wrong? I can heal toe in and other car but this one. Its like it was setup to not be able to unless you are under very hard braking conditions.
I will look at the pedal extensions as an alternative.
phil
Not your temple - under your chin and open your mouth - it does work.
Old Jun 7, 2010 | 09:23 AM
gloves's Avatar
gloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud of
LOL. Both keys have the same range. I am going to get new batteries soon.
Old Jun 7, 2010 | 09:28 AM
jhbrennan's Avatar
Originally Posted by GIjbop
Re #2
all i know is i brought my car in to the dealership for a minor repair....afterwards..my car beeps when i lock it...perfect!
Unless you have the Smartop Remote Key module, a beep on locking indicates something is not closed - glovebox?
Old Jun 7, 2010 | 11:27 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Just took a second look at the extensions. Problem is they are just width extension, from what I can tell. I need the gas pedal to be out more at the top. The plain difference between the brake and the gas makes it so I have to either be braking super hard or must put a whole lot of heal into it, which is a very odd feeling. I dont know what to do as I now find myself doing it on a normal basis like I have been and missing
Rennline sells a Pedal lifter plate that will solve your problem. They also have various pedal options designed to improve heel toe shifting in your Porsche.
Old Jun 7, 2010 | 11:37 AM
gloves's Avatar
hey thanks for the info. i still dont seem to understand why they made it so hard to do when not braking very hard.
Old Jun 7, 2010 | 12:09 PM
NorthVan's Avatar
That is the point, there is no need to raise the pedal, as they are the same height from the floor when the brake pedal is full engaged.
Old Jun 7, 2010 | 12:19 PM
mgf997's Avatar
mgf997 is a name known to allmgf997 is a name known to allmgf997 is a name known to allmgf997 is a name known to allmgf997 is a name known to allmgf997 is a name known to all
For #2 I have the same @#$@ problem! Have heard many different possible solutions, but only really know of a aftermarket mod from mods4cars = http://www.aftermarketbulbsshop.com/v/vspfiles/downloadables/RK997.pdf
Old Jun 7, 2010 | 12:49 PM
NorthVan's Avatar
As per your thread, this works well.
Old Jun 7, 2010 | 02:41 PM
rye595's Avatar
rye595 is a jewel in the roughrye595 is a jewel in the roughrye595 is a jewel in the roughrye595 is a jewel in the rough
I have to say, I don't share this problem... heel-toe is a technique that allows you to downshift smoothly under hard braking, without upsetting the balance of the car. If the pedals were setup to allow you to easily practice heel-toe when cruising around town, they wouldn't line up correctly under hard braking on the track.
Old Jun 7, 2010 | 03:44 PM
gloves's Avatar
True, but unless the brake travel is huge it shouldn't really be an issue. I just got used to it on my last car in DD use so I am sad about not being good at it.
Old Jun 7, 2010 | 04:05 PM
pcs's Avatar
pcs
pcs has a spectacular aura aboutpcs has a spectacular aura about
Give it time - I had the same issues at first, but as I got used to the car, everything became much easier and more natural. I wouldn't change a thing in the pedals now.
Old Jun 7, 2010 | 06:28 PM
cbzzoom's Avatar
cbzzoom is infamous around these parts
IMO the pedal placement is perfect for heel-toe. This is one of the things Porsche does well - it is where racers want it because you should be doing it when you brake hard. Give it time, you will get used to it.
Jul 29, 2019 11:13 AM
