Official Porsche IPOD hook up - poor sound quality?
Old Jul 31, 2010 | 07:34 AM
msgm1's Avatar
msgm1 is infamous around these parts
I had my dealer install the ipod hook up for my 2007 997. However the sound quality is not great and in between tracks on when the music is quiet you can hear quite a lot of hiss like radio interference (you play it on the fm setting even thought it is a direct wire connection not fm modulated). Anyone else have this problem?
Old Jul 31, 2010 | 09:35 AM
P997S's Avatar
P997S is infamous around these partsP997S is infamous around these parts
no - mine works flawlessly
Old Jul 31, 2010 | 12:49 PM
TooSixy's Avatar
TooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant future
Since yours is a 2007, the OEM iPod interface is FM-modulated. That may explain the radio interference.
Old Jul 31, 2010 | 12:56 PM
msgm1's Avatar
Really is it fm modulated? The ipod is connected via a cable to the pcm..???
Old Jul 31, 2010 | 01:11 PM
TooSixy's Avatar
The iPod is connected via the USB docking cable, but the iPod-to-PCM interface is FM-modulated.
socalsteve's Avatar
socalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to all
Do you have to set a certain FM radio frequency (like 88.9) to listen to the ipod? If you hear hiss and the sound quality is not great and you have to set a certain FM frequency, then chances are pretty good (I would say 100%) that it is FM modulated.
The ONLY way to get it to sound half way decent is having a direct connection.
I hope the stealership didn't charge you a lot of money to do this. You could have done this yourself for less than $100.00 from any Apple store or even Radioshack.
Good luck!
Steve
PS: Get your $$$ back from the stealership and invest in a good aftermarket head unit. You will get many more great features and the sound will be much better.
PSS: Probably the ipod is connect via cable to the PCM to the antenna. Again, a very poor way to do what you want done.
Old Jul 31, 2010 | 01:29 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
On your 997.1, unlike a 997.2, you can't connect to the PCM via a cable. The Porsche solution is an FM modulator, and even if it is inserted into the antenna leads like a 3rd party one I purchased, it is still subject to the shortcomings of FM (like lame frequency response and presence of some noise). It is best to install a Dension or equivalent that ties directly into the fiber optic loop system. It will give you much better sound as well as the ability to control via the PCM.
Old Jul 31, 2010 | 05:59 PM
Gator Skin's Avatar
Gator Skin is infamous around these parts
Yes, indeed the Porsche "official" Ipod connector for the 997.1, as others have stated it a glorified FM modulator, but it does fit neatly with the car. Again, you can get better performance/clarity at a much cheaper price with a run of the mill AutoPilot FM modulator for 60 bucks.
Old Jul 31, 2010 | 06:16 PM
msgm1's Avatar
Thanks guys for the info. The dealership told me that the ipod hooked directly into the fiber optic of the pcm, guess not as I do have to switch on the fm radio and search for AUX to hear the ipod...
Old Jul 31, 2010 | 06:35 PM
Gator Skin's Avatar
This is what you are referring to, correct?
http://www.suncoastparts.com/product...997ELECTRONICS
Old Jul 31, 2010 | 08:05 PM
KK Moto's Avatar
KK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud of
Please tell me my parts manager told me wrong. I have 997.2 and asked to have the ipod goodies installed. He said "don't do it.....FM Modulated.....Won't be happy....." I'm really tiring of CD's, XM, terrestrial.....
Can I have the ipod directly connected. please, please, please?
Old Jul 31, 2010 | 08:09 PM
bbywu's Avatar
PCM 2.1 has an OEM iPod adapter - uses a FM modulator.
PCM 3.0 has an OEM iPod adapter - direct output (although older cables will not charge firewire based iPods. An updated cable is necessary - one with a USB/iPOD hybrid - to charge newer USB based iPods.)
Old Jul 31, 2010 | 08:34 PM
JohnAMG's Avatar
JohnAMG is infamous around these parts
I am also having the ipod adaptor install in my 09'C4S this coming Wednesday. From what I know the kit for our car is directly hook up to the PCM3 and fully controllable from MF steering wheel and PCM. I guess I will double confirm with the dealer Monday.
John
Old Jul 31, 2010 | 08:46 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Yep, the old one is FM modulation crap wrapped in a Porsche label. Only the Dension is going to get your a direct fiber optic PCM connection.
Old Jul 31, 2010 | 08:51 PM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
Porsche should be ashamed to have released such garbage with their name on it. In any, even average sized, city, an FM modulator is complete crap.
There are so many options out there ranging from integrating into the fiber optics, splicing into the antenna cable or just simply adding an aux port.
I just think that the modulator is crap. Even the monster brand products are bad.
