Help with Horn location?
Old Aug 21, 2010 | 06:32 PM
h1sp's Avatar
h1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud of
Can anyone hook me up with the horn location?
I think I have one out, my horn sounds mono tone. I would like to check the wires before I run to the dealership.
Old Aug 21, 2010 | 08:48 PM
996-Sam's Avatar
996-Sam is infamous around these parts
I have a 996, and on my car the two horns are behind the front bumper, on the passenger side. I had to remove the bumper to get to them.
Old Aug 21, 2010 | 09:41 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Sure, here you go, take a look at the attached photos I took when doing the SC installation:
In the first shot, it's the small round unit about fist-sized (black with a silver top) that sits about half way between the passenger-side front radiator and the steel bumper-reinforcement bar.
In the second photo, you can see the horn assembly dangling from it's wiring harness. Hope this helps, if so repay my effort with rep points!
CATTMAN
Old Aug 22, 2010 | 01:59 PM
h1sp's Avatar
Yep it helps, Thanks... Its going to the dealer
jaehoppa
Oct 22, 2015 09:17 PM
