Gremlins on the dashboard.Help!
Old Mar 3, 2005 | 03:01 PM
zoltan's Avatar
zoltan is infamous around these parts
Lately i hear some rattles behind the dashboard, somewhere between the ''chrono wathch'' and the back of the glovebox.
I have just covered 3000 km (it's a 997S) and it's getting worse as i pass over bumps. The dealer can't find where the rattle comes from. Is anyone out there with the same problem?
Please help.
Old Mar 3, 2005 | 03:47 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Years ago this was often caused by airbag related stuff on the passenger side of the dash. Glad to see Porsche is consistent. Must have emptied the old parts bin for that one.
Did you drive along with the service tech? That would be the best way to try to id these problems. Probably some insulation up under there that can solve this, unless something is really loose.
Old Mar 3, 2005 | 03:48 PM
DJ's Avatar
DJ
zoltan they all have a creaky little gremlin somewhere - unless you really pull apart the dashboard and do some kind of insulation (not OEm) there will always be something
get an exhaust system or turn the radio up
Old Mar 3, 2005 | 04:06 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
I'd second that recommendation if it were a Toyota...
Old Mar 3, 2005 | 09:27 PM
roadking's Avatar
roadking is infamous around these parts
I had the same problem. I took the vehicle back four times and the dealer could not find it. After about 2 hours, I cured the noise. My problem was coming from the glove box side of the dash. I isolated it down to a rattle coming from behind the far cup holder. If you open the glove box and the cup holder panel, you will notice a seam between the top dash section and the bottom. Insert a flat blade screw driver and gently push in. Check to see if the noise is gone. Mine was. I inserted a piece of foam approx 2" wide by 1/4" thick and remove the screw driver. The dash has been quiet since. I also used felt around the gauge cluster and removed the cig lighter, all sources of rattles.
PM me and I can take a couple digital pics if you like. It cured my issue.
Kind of sad for an $80K+ car. My Scion doesnt rattle at all and cost only slightly more than a Bic razor.
Old Mar 3, 2005 | 11:28 PM
zoltan's Avatar
thanx for the advice roadking.
By the way, Toyota's do not rattle... especially at these areas.
My previous M3 E46 was a drifters delight (too much stress on the joints) and it was extremely silent
Old Mar 4, 2005 | 10:12 AM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Porsche always rattles, when you buy a Cayenne, you drive it home, it will rattle on the way home... Get an exhaust and you will be fine
Old Mar 4, 2005 | 10:37 AM
zoltan's Avatar
Deetz, i' ve driven several Porsches but this is my first own Porsche and i haven't noticed that before. If teutonic Porsche always rattle so what can you expect from a latin Ferrari?
Old Mar 4, 2005 | 09:42 PM
GoFast996's Avatar
GoFast996 is infamous around these parts
It's the flap mechanism on the vent. Let me know if you find out otherwise. Good Luck.
Old Mar 4, 2005 | 10:21 PM
AMG ETR's Avatar
Is this the Zolton I know from S. FL??? If so, wassup man and congrats!! If not, good luck
Evan
Old Mar 5, 2005 | 03:52 AM
zoltan's Avatar
AMG ETR, i wish were in Florida. But i'm in Athens. Thanx anyway.
Old Mar 6, 2005 | 01:35 PM
schicago's Avatar
schicago is infamous around these parts
i had a 2001 boxster s which had rattle in dash problems the dealer had to take out the dash drive the car to id the rattles then reinforce a strut as well as insulate it. after the fix no more rattle.
Old Mar 6, 2005 | 01:37 PM
schicago's Avatar
i had a 2001 boxster s which had rattles in dash problems the dealer had to take out the dash drive the car to id the rattles then reinforce a strut as well as insulate it. after the fix no more rattle.
Old Mar 6, 2005 | 01:43 PM
schicago's Avatar
Old Mar 6, 2005 | 02:53 PM
shiggins's Avatar
Official Dipshit 2006
shiggins is infamous around these parts
I get the feeling you have a 2001 boxster S that rattled schicago
