engine vibration at 2800RPM
Old Dec 12, 2010 | 09:25 AM
WTFitsCarter's Avatar
WTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant future
I am getting a slight vibration at 2800 RPM when driving, standing still, clutch engaged, clutch not engaged.. I am guessing it could be a motor mount?
Old Dec 12, 2010 | 09:41 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
impossible to diagnose on the internet...take it to the dealer.
Old Dec 12, 2010 | 09:56 AM
mdrums's Avatar
...just thinking....do you have aftermarket exhaust? If so go look at the brace that extends from the lower rear 1/4 panel and goes just infornt of each side muffler to the frame. Sometimes if that brace is not re-installed just right it cane touch the muffler and create a vibration.
Old Dec 12, 2010 | 10:36 AM
car is 100% stock at the moment but i will check that area out.. i was thinking maybe a bad motor mount? i drive the car hard so who knows if it has worn out after 63k miles on it..
Old Dec 12, 2010 | 11:34 AM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
I don't get a vibration but sometimes around 2800-3200 RPM I get what I call a slight settling of the engine.....
could it be the same thing?
Old Dec 12, 2010 | 10:29 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
If you mean a change in engine characteristics while accelerating this coincides with variable cam kicking in.
Old Dec 13, 2010 | 05:37 PM
buck986's Avatar
could be...thanks
PelicanParts.com
996 Turbo Vendor Classifieds
Sep 8, 2015 09:41 AM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
PelicanParts.com
Aug 25, 2015 03:43 PM
PelicanParts.com
Aug 25, 2015 03:35 PM
PelicanParts.com
996 Vendor Classifieds
Aug 25, 2015 03:31 PM
