Power to nonpower seat question
Old Feb 13, 2011 | 09:16 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Going from powered adaptive sport seats to nonpower sport buckets. Not familiar with the connections under the seat, but will there just be a connector/module left unplugged when I go to the buckets? Will this throw a code that needs to be cleared/deactivated by PIWIS? Thanks for any info.
Old Feb 13, 2011 | 09:42 PM
bbywu's Avatar
I'm 99% sure there are two harnesses under the seat, one for the airbag system, one for the power seats. When you install OEM buckets, the new seats come with the control units under the seat, so it is plug and play.
With non OEM buckets, there is nothing to plug into. I know PIWIS can turn off the side airbag and even the seat belt warning system. Not 100% sure about the seat sensors though, but I know a few guys here have done the swap with no warning signs. I doubt Durametric can do it, you'll need PIWIS.
I'd PM Ray or one of the other vendors who sell non OEM seats to be sure.
Old Feb 13, 2011 | 09:47 PM
bbywu's Avatar
I also know utkinpol has done it with Recaros:
https://www.6speedonline.com/forums/...orster-cs.html
bonehead's Avatar
With non OEM buckets, there is nothing to plug into. I know PIWIS can turn off the side airbag. Not sure about the seat sensors though.
To clarify, I will be getting OEM GT2 sport buckets. I know the airbag harness will plug into the seat, but what happens to the power control unit harness? Does this just hang in the breeze? If so, does it need to be deactivated?
Old Feb 13, 2011 | 09:53 PM
bbywu's Avatar
For aftermarket seats, apparently, PIWIS needs to program the following:
Driver Thorax Airbag : No
Passenger Thorax Airbag : No
AWS : No (Automatic weight sensor for passenger seat)
Remaining passenger side air bags will always be armed (Passenger Air Bag Disarmed light will flash 3 times when car is started then go out)
Old Feb 13, 2011 | 09:54 PM
bbywu's Avatar
Does not appear so.
https://www.6speedonline.com/forums/...onversion.html
Airbag harness plugs in, power/seat sensor plugs in.
bob
Old Feb 13, 2011 | 10:03 PM
bonehead's Avatar
Does not appear so.
bob
I read that thread before, but the big difference is mikymu has the non power sport seats.
So, the seat sensor utilizes the same harness as the power functions?
Old Feb 13, 2011 | 10:12 PM
bbywu's Avatar
I thought those seats had power backrest?
Old Feb 13, 2011 | 10:17 PM
bonehead's Avatar
You got me, Bob. I thought they were fully manual??
Old Feb 13, 2011 | 10:47 PM
yrralis1's Avatar
Just a few things that i recall as i almost did the swap a few years ago -
1) Unless they are ordered with the car the only color choice after the fact is black .
I have a black car so this was a good thing for me.
2) They can be installed . I don't know the technical aspects but installtion was presented to me as a simple thing.
3) They are not too cheap ... about 7K or so if i recall .
4) One forum member did post that on long distance drives they can become a bit uncomfortable . Maybe I am just getting old .. he was middle aged as well.
5) I fit in them with no problem . So does my girlfriend .
However .. I have driven with passengers who may not fit so easily . Something to consider.
Old Feb 13, 2011 | 10:55 PM
Jay Jones's Avatar
Jay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to behold
I just did this swap last fall. Power/heated OEM seats for OEM GT2 Sport Buckets. Under the passenger seat, both connections match up. Under the drivers seat, we zip tied the extra connector to keep it secure. No codes were thrown, it was a very simply plug and play.
Just to be clear, these GT2 Sport Buckets are fully manual, no power whatsoever.
Jay
Old Feb 13, 2011 | 10:57 PM
bonehead's Avatar
Jay
Thanks Jay! That's the answer I was looking for! What is the 'extra' connector under the driver's seat? Did you throw an airbag fault or did you somehow avoid it?
Old Feb 13, 2011 | 11:05 PM
Jay Jones's Avatar
Never tossed an airbag fault or code throughout the process. My understanding is that the extra connector under the drivers seat is for the power that is no longer needed with the sport buckets. Either that or for the heating feature, I'm not 100%. I strongly suspect it's for the power though....
As far as the installation goes, you will want to disconnect your battery and let the car sit for at least 30 minutes before unhooking anything under your seats. This is where the airbags can become a problem if you start unplugging too fast.
Jay
Old Feb 13, 2011 | 11:08 PM
bonehead's Avatar
Jay
Good info, thanks again! So, one seat accepts 2 harnesses (passenger) and one seat accepts 1 harness (driver), thus leaving one extra harness on the drivers side?
Old Feb 13, 2011 | 11:18 PM
Jay Jones's Avatar
I just ran down to the garage to confirm everything for you. Both modules are connected under the passenger seat. The small connector under the drivers side is the one that is unused and zip tied off.
Jay
