Battery Tenders ?
Old Mar 12, 2011 | 06:03 PM
Mark Ducati's Avatar
Mark Ducati is infamous around these partsMark Ducati is infamous around these parts
Battery Tenders ?
How many of you use a battery tender on a regular basis?
My battery went dead about a month ago...
When I called the Porsche Service Department, the tech told me that the 997.2 draws something like 26.5 amps (maybe mA?), not sure of the correct term... but his point was that just about all the current the alternator generates is going to run the car during its operation and very little goes back to charging the battery.
I drive 8 miles a day total (4 to and 4 from work)... he told me that 8 miles isn't enough to keep the battery charged and when I told him when I bought the car, he said he was surprised the battery lasted that long.
His suggestion was to buy one of those cigarrette lighter battery tenders that plugs into the garage wall... and plug it in every night when I get home from work.
So, do any of you guys use tenders?
Old Mar 12, 2011 | 06:06 PM
GT3 Chuck's Avatar
Administrator
the batteries in these cars are such wienies that unless you drive them every day you need some kind of battery maintainer...I have a Battery Tender and it works great...I don't use it all the time especially when I can drive the car every other day and it isn't necessary...but over time the battery will run down and it will need some charging and a maintainer will not substantially charge the battery but will give it enough to get it started...when it sits longer I will leave it on overnight and that seems to give it a pretty good charge
Old Mar 12, 2011 | 07:55 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
I tend to agree that 2 daily runs of 4 miles each may indeed not be enough to recharge the battery and replenish the starter energy loss. I would recommend that you either get the OEM dual-mode charger or the CTek similar model. If you get the CTek do get also the cigarette lighter adapter, the easy/preferred way of connecting it.
You do not need to connect the charger everyday, but you may need to do it one full night, once a week.
Old Mar 12, 2011 | 08:08 PM
Steve997S's Avatar
Steve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond repute
I have the Battery Tender with alligator clips. Haven't used it with my Porsche (but should considering how seldom I drive it--comparatively with my DD). If I did, are there terminal points on the chassis to connect (like BMW)? Guess I need to buy the Porsche charger...
Old Mar 12, 2011 | 08:24 PM
adias's Avatar
You can also get a cigarette lighter adapter for Battery Tenders.
Old Mar 12, 2011 | 08:39 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
Seeming non-sequitur, and I know you clarified it with the mA, but just for your general knowledge...
Voltage x Current = Power
You have a 12 volt battery, so 12V x 26.5A = 318 Watts
... and 1 horsepower = 746 Watts
I hope your car doesn't use 1/2 horsepower at rest
Old Mar 12, 2011 | 09:10 PM
adias's Avatar
I agree (rep points added ) - the parasitic idle current is about 25 mA. But the key issue is that the energy consumed in starting the car, VIt, where I is in the 100s of Amps is not recovered by charging in a short 4 mile drive.
Old Mar 12, 2011 | 10:04 PM
-Rick-'s Avatar
-Rick- is infamous around these parts-Rick- is infamous around these parts
This is for the Canadians... This http://tinyurl.com/66qhlrh is what I use, works great and 20 bucks cheaper because it doesn't have Porsche stamped on it
Old Mar 12, 2011 | 10:07 PM
mattyf's Avatar
Excellent point, I definitely agree!
We could estimate a high 500 amps for 1 sec, which would be:
500 A-s = 8.3 A-min = .13 A-hrs (which doesn't sound like much to me, a standard car battery is around 40 A-hrs)
But sadly most battery manufacturers no longer list a-hrs, only "cold cranking amps." Oh well ;(
And as to your point, we'd also really need to know the rectified voltage put out by the alternator and the resistance of the battery as it charges to figure out if a 4 mile run would charge it back up.
Lastly as an aside, I usually hardwire battery tenders to all my motorcycles batteries.
Old Mar 13, 2011 | 06:50 AM
MI55LE's Avatar
MI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to behold
battery tender = cheap insurance
my "nice" cars are not DDs and I've always used battery tenders
Old Mar 13, 2011 | 06:58 AM
Jeff C's Avatar
Jeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of light
I use a cigarette plug in tender 90% of the time. Wal Mart has them as well as the dealer. I drive my car couple days a week at best.
Old Mar 13, 2011 | 08:59 AM
na011's Avatar
na011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nice
4 tips to get your battery to last to the max:
1) Use a battery tender
2) Check the water level often & add distilled water when needed. You have to remove the stickers on the top to get to the fill plugs.
3) Lock the doors. This will allow the car to get into the "sleep mode" and thus it will draw lower amps.
4) Keep the battery post clean of any acid build-up.
Old Mar 13, 2011 | 10:33 AM
DaveHutchinson's Avatar
DaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond repute
I have one of these very chargers spare now if anyone needs one. I'll stick it up for sale in the marketplace or you can just PM me.
Old Mar 13, 2011 | 11:13 AM
Flying Cat's Avatar
Flying Cat is infamous around these partsFlying Cat is infamous around these parts
+1 Battery Tender. I have used it for years with my C2S and keeps the battery always charged. You should check Amazon.com, they sell them for under $50.
Old Mar 13, 2011 | 01:05 PM
Thanks fellas,
And Adias, thank you... I have a battery tender that I keep on my Harley, it didn't come with cigarette lighter adapter, but now I see that would be cheaper than buying another tender.
Thanks,
M.
