1st gear trouble, 2007 997?
Old May 17, 2011 | 06:40 AM
antonio 997's Avatar
antonio 997 is infamous around these parts
Hi All,
so, called the dealer and he told me to bring the car back for the brake sensor light.
i forgot to mention another item to him that i should of. but, i wish to know if this is common before i say anything to him.
I at times, have trouble putting the car in 1st gear. the rest of the gears are fine, but that first gear!!!! at times, i really have to force it in.
any thoughts.....
Old May 17, 2011 | 06:56 AM
WTFitsCarter's Avatar
WTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant futureWTFitsCarter has a brilliant future
Does this happen more when the car is cold or does it happen even when it's hot?
Hi All,
any thoughts.....
Old May 17, 2011 | 06:58 AM
I will note it
Hi,
I will note it in the future when i drive home this evening.
thanks
Old May 17, 2011 | 07:33 AM
texas355's Avatar
texas355 has a spectacular aura abouttexas355 has a spectacular aura abouttexas355 has a spectacular aura about
I sometimes have the same problem, hot or cold. I am curious too.
Old May 17, 2011 | 07:34 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
"normal"
Old May 17, 2011 | 08:24 AM
strife_wy's Avatar
strife_wy has a spectacular aura aboutstrife_wy has a spectacular aura about
Mine has been doing it since day 1. If you double-clutch to get into first it usually goes into gear smoother. I suspect it's just tight build tolerances on the synchros.
Old May 17, 2011 | 08:49 AM
Johnny DB's Avatar
I have the same problem. I always go into 2nd gear first, then up to 1st gear.
Old May 17, 2011 | 10:45 AM
JT997's Avatar
JT997 is infamous around these parts
I noticed mine doing it, too. Very rarely, and it seems to happen more when it's cold.
Old May 17, 2011 | 12:00 PM
DÜnkleblau S's Avatar
DÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant future
es normal; particularly if you have a short shift kit
Old May 17, 2011 | 03:24 PM
surfah's Avatar
surfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond repute
Happens not infrequently. Double clutch before 1st or go straight to 2nd as others have mentioned.
Old May 17, 2011 | 04:01 PM
DirtyVegas's Avatar
DirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud of
I suppose we are all glad to know that it is a 'common' issue and that it is not an issue with our particular car... but wouldn't you expect Porsche to create a smoother 1st gear technology? Even my finance thinks its a bit funny when I have to massage the 1st gear in on a cold start when we drive.
This is the least smoothest 1st gear out of all stick cars I have driven yet (american/jap/euro)
Old May 17, 2011 | 09:18 PM
Vancouver-BC's Avatar
Vancouver-BC is a jewel in the roughVancouver-BC is a jewel in the roughVancouver-BC is a jewel in the rough
Same here, when the car is cold, first gear can be tough to engage. Double clutching or going into second before reengaging first seems to help.
Old May 17, 2011 | 09:35 PM
dark911's Avatar
dark911 has a spectacular aura aboutdark911 has a spectacular aura aboutdark911 has a spectacular aura about
this is normal, they all do that.
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
pnoob2
Oct 31, 2015 06:34 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
metzkaro
Aug 24, 2015 02:59 PM
