GT3 throttle body retrofit to 997
Old Mar 16, 2012 | 10:19 AM
  #61
Johnny DB's Avatar
Originally Posted by Gpjli
by now you might be getting a not so good feeling about this
This is what happened when the first IPD plenum was tested....dyno results were not favorable.
Old Mar 18, 2012 | 04:08 PM
  #62
michaelr1's Avatar
michaelr1 is infamous around these parts
Dyno Results
Originally Posted by alpine-al
Any dyno results yet?
I have not had a chance to rerun on the dyno. The AWD is the culprit that I have been told caused the fluctuations. Between work and moving I haven't had a chance to get it done. My lack of response is certainly not a negative on the install, as all is well.
Old Mar 19, 2013 | 01:03 PM
  #63
Arerrac911's Avatar
Arerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant futureArerrac911 has a brilliant future
Does IPD recommend GT3 throttle body upgrade with their new 997.2 DFI IPD plenum? If so, do you offer a kit (plenum + TB) that directly bolt on to the factory hardware just like the 997.1 kit?
Old Mar 19, 2013 | 01:16 PM
  #64
IPD Greg's Avatar
IPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond reputeIPD Greg has a reputation beyond repute
The 997.2 Carreras (both S and Non S) come from the factory already equipped with the 82mm TB, which is still the largest Porsche TB available.
There is only one 997.2 Carrera Plenum option for this application.
Thanks for all the interest,
IPD Greg
Old Mar 19, 2013 | 02:47 PM
  #65
Gibbo205's Avatar
Gibbo205 is a jewel in the roughGibbo205 is a jewel in the roughGibbo205 is a jewel in the rough
Hi there
Does fitting the competition plenum and 82mm throttle body loose any low-down power/torque on a 997.1 C2S?
At the moment got BMC panel filter, X51 manifolds and 200 cel high-flow cats. Would the plenum/82mm throttlebody give me more torque and power across the whole rev range?
Old Mar 20, 2013 | 07:46 AM
  #66
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
It won't reduce your torque at low RPMs. You might not realize an improvement at low RPMs either.
Intake improvements tend to benefit the mid to high rpm range. Improvements on the intake side reduce the resistance to airflow which allows the engine to suck in more air. Yet at low RPMs there isn't much resistance to begin with. (The volume of intake air is smaller at low rpms so it is less restricted.)
turbotuner20v
Sep 11, 2015 12:02 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
magoochi
Aug 23, 2015 05:54 PM
TrackOne
Aug 20, 2015 12:56 PM
