Shifting Technique with Manual Transmission?
Old Jul 28, 2011 | 07:43 PM
Manifold's Avatar
Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !Manifold Is a GOD !
Originally Posted by simsgw
That preparation is about what I guessed from your questions or I wouldn't have bothered with a detailed answer. As many of us will confirm, a few days with Skip Barber in Formula Fords or at Porsche's performance driving school are worth more than a year of DE days.
The brief answer to your question is yes. Less briefly, to justify that:
We need a brief diversion into terminology. To an R&D engineer, the pattern of the vehicle's thrust is more important than the edges of the road, so I tend to think of the apex as being the inflection point in that curve, the point where you transition from braking *** cornering to acceleration *** cornering. And if you have a cornering sequence that requires the tires' grip be devoted to maximum cornering, with neither braking nor acceleration (except from drag), than the apex would lie at the point where acceleration began again. If it was noticeable at all, then a second apex would precede that for analysis purposes. That would be the point where braking had to be abandoned to permit that maximum cornering grip. (Usually the point where a good driver completely releases brake pressure isn't noticeable at all. In geek terms, it doesn't cause an inflection.)
All very theoretical and not what my driver's intuition calls an apex of course. We think of our apex as the closest approach to the inside of the corner, which sometimes includes putting the inside wheels off the pavement. The theoretical approach is needed for analysis, if only because we often race on courses that compel an apex that may be a hundred feet from the edge of the pavement. Converted airport tracks are notorious for this. If I must achieve 200 degrees change in direction in a couple of hundred yards of WWII pavement, does the lack of an edge mean I had no apex? Of course not. And novices at such tracks are taught to pick up on the past rubber deposits and think of those as the track surface, planning their apex by the closest approach to the edge of that pattern of rubber on the much much wider pavement. For DE days, they add pylons of course to make these things more visible.
Okay, with that pettifogging out of the way, let's stick with a driver's intuitive meaning of apex. That's the one you'll see in books by non-engineers so we better use it. That means the answer is yes. Many corner complexes require acceleration to begin before reaching the inside edge of the track, before that intuitive apex. The reason in racing is that speed at different parts of the track has more effect on the lap time than others. If the section following the upcoming corner is one we want to take at the highest speed possible, then we take a "late apex" allowing us to accelerate before the apex and leave the corner at a higher speed. The apex comes after the "thrust inflection" of us engineers, but it also is positioned further down track because we did so much of the cornering before reaching it to allow early acceleration. That makes it 'late' even to drivers' intuition. I believe it was Graham Hill who first brought this to public notice back in the seventies. (By winning this way of course.)
The converse is also appropriate although it worries us when teaching novices. An early apex is one where the inside edge is reached before you finish trail braking, or at least before you can begin acceleration. We need an early apex when the preceding track segment, like a long straight perhaps, is more important to the lap time than the segment following. For the best lap time we need to carry the speed as deep into that corner as possible. We also use this to pass other cars, but that really isn't covered in early training. The early apex means a very delayed start of braking and that means using as much of the corner as possible to scrub off the rest of that oh-so-desirable speed that now is keeping us from getting the car turned and accelerated into the following segment. It may be less important than the preceding straight, but we do want to traverse it from the track surface instead of hanging on a tree limb or spinning off into the desert (where I live now, we don't keep trees. At least not around race tracks.). And when racing, if you use that late braking to pass, then you don't want the other driver to do an "over and under" move by using a late apex and early acceleration to blow past your desperately cornering car. (But I never mentioned that. You never read that here. This isn't race training by e-mail. Honest.)
On public roads, I don't even consider an early apex. And they are not taught to novices at DE days either. In fact, I think the PCA doctrine for instructors is not to teach trail braking either. It's that same issue of learning first to blend acceleration and cornering instead of learning the more difficult skills. You need to have building blocks in learning. Even when we know the theoretic basis for more advanced techniques, we need to let our motor skills progress by the one-step-at-a-time approach. Besides... if you get a late apex wrong, you simply blow your lap time. Backing off on acceleration saves you from departing the track for example. But if you blow an early apex, you're already committed and likely to need a vacuum cleaner to get the sand out of places you never knew it could reach. You will go faster if you get it right, but you must get it right or spend time communing with desert tortoises. Or a tree. Including "must do it right" segments isn't the way you teach a subject like driving or flying. Uses up students for one thing.
So the overall answer is yes, once you learn to hit your apex, which isn't a trivial skill, then you learn how to start acceleration beforehand or finish your braking afterward. Either skill should come later, but in fact the safety benefits of a late apex usually mean that that technique is the way people are taught "the racing line" even when real racers might be using an early apex at some of the same corners.
For now, just learn to hit the apex wherever an instructor tells you it should be. Learning to put the tires over particular spots on demand is itself a fundamental skill you want to learn. Later you can learn to pick the apex yourself for the best lap time.
Gary
Another great post ... thanks.
I like your distinction between thrust vs. geometric apexes. I haven't seen that before, but it certainly makes sense.
In my driving so far, I suppose that I've usually more or less had the two apexes coincide, though there have probably been exceptions to that if I really think about it. I'm going to pay attention to this going forward.
And I have been aiming for late apexes, as you suggest, primarily for the safety reason you noted. I'm not keen on crashing as the penalty for a mistake.
As far as my training, it was with the AMG Driving Academy (at Lime Rock), which I suspect might actually be conducted by the Skip Barber School. The instructors were all pro racers (including Tommy Kendall), and it was quite a thrill to go on a "hot lap" with them to see how experts do it.
BTW, are you an engineer? I am, and I gathered from your post that you might be too.
Old Jul 28, 2011 | 09:30 PM
Rodolfo's Avatar
Rodolfo is infamous around these parts
Heel and toe is not really necesary with modern syncronized transmissions.
It was a most, maybe 30 years ago, but now, if you match your car speed with your engine speed, gears almost can go in without using the clutch.
Try going full speed to fourth or fifth, then brake really hard and downshift to fourth, third and second. Gears will go in with no problem.
Most of the downshifting will go down before you enter the corner, and you will be controlling the throttle before you get to the middle of the corner.
Old Jul 28, 2011 | 10:09 PM
simsgw's Avatar
simsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond reputesimsgw has a reputation beyond repute
Yes, I was suspecting you were also. Again, that's why the detail in my answer. Lots of stuff there an art history major would just find boring.
Gary
Old Jul 29, 2011 | 07:17 AM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
Are you referring to on the street?
On the track it is certainly necessary. At least in my experience.
Old Jul 29, 2011 | 08:15 AM
Rodolfo's Avatar
Yes, I ment on the track, I only use it on the street if I am laisy and want to shift form 4th to 2nd, On the track I will got 4th, 3th, 2nd, and no rev matching will be necesary.
Not meaning to start an argument, but when do you use it on the track?
Maybe we could share points of views, and improve our driving teknics?
Old Jul 29, 2011 | 08:30 AM
Manifold's Avatar
Not sure I understand.
Are you saying that that gears can be shifted by using little or no clutch? If that's even possible, doesn't it cause damage?
Also, when you say brake hard and downshift, are you saying brake then downshift, or do both at the same time? If same time, that goes back to my original question about whether revs need to matched and heel/toe is needed.
Thanks.
Old Jul 29, 2011 | 08:35 AM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
with some skill it is possible to get gear out and even out it in with no clutch depress but in reality on a track when you braking hard you cannot do it, you must heel-n-toe.
sunts like no clutch etc are more common for sequential boxes that have straight gears, but on regular 997 street gearboxes it is some trick to engage a gear with no clutch. i see no point in damaging gearbox this way.
Old Jul 29, 2011 | 09:14 AM
Devils Advocate's Avatar
Devils Advocate is infamous around these partsDevils Advocate is infamous around these parts
In spirited driving situations and track, when you don't rev match and just pop the clutch that immediate power transfer(that big lurch you feel in the car when you do this) can break traction mid-corner and cause you to spin out, or at the very least ruin the fluidity of your driving, thus slowing you down. Not to mention the huge amount of wear and tear you put on your tranny by not "helping" them in such demanding driving, that's a lot of power transferring going into the transmission at those shift points, especially at high rpms.
Old Jul 29, 2011 | 10:03 AM
Rodolfo's Avatar
Next time you are on track, or on the street, go full throttle to 5th, then brake hard and start downshifting the gears.
ALL THE TIME YOU CONTINUE BRAKING
Clutch, then put 4th, then de-clutch
THEN
Clutch, then put 3th, then de-clutch
then
clutch, then put 2th, then de-clutch
STOP BRACKING
gears will go down rather smoothly, and you are ready to turn into the corner and start giving thorttle.
Just try it, today at the street, or this weekend on the track.
If you think that damages the transmission, you should give more credit to your 100k car.
But as I say, first try it, and then come back and post your opinions.
Old Jul 29, 2011 | 10:32 AM
utkinpol's Avatar
THEN
then
STOP BRACKING
problem is never with gear coming into new position in the gearbox, heel-n-toe gets done to minimize transitional 'jerk' when you release clutch and gears engage.
if you are trailbraking into a corner at 9/10 and then you jerk car too much during downshifting you will loose grip and spin out.
as of syncros allowing gear to get in - it is never a problem, problem is to complete all transitions smooth without upsetting car`s balance.
Old Jul 29, 2011 | 12:00 PM
Manifold's Avatar
THEN
then
STOP BRACKING
Sounds scary and counterintutive, but I suppose I'm willing to try it (in a straight line). I'll report my findings. Fingers crossed.
Old Jul 29, 2011 | 12:19 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
bingo.
on the street, i usually do the following for a sharp turn:
1- brake, if necessary (sometime just letting the gas out is enough to slow down)
2- double-clutch to proper gear
3- turn then accelerate
if i am in a hurry ()
1- brake and shift (heel/toe.. or big toe/pinky toe, if u have pedal extenders )
2- turn and accelerate
1. At what rpm do you typically shift from 1st to 2nd? I find 1st to be kind of annoying because you have to shift fairly soon to 2nd, whereas the car needs decent speed to handle 2nd without bogging, so getting the car off the line fast is a bit of chore. But maybe I'll get much better at it with practice (which is certainly my goal).
i usually shift 1-2 around 4300-4500 rpm when driving 'normal'.. close to redline, if driving 'spirited'
BTW i am still digesting all the good info from simsgw..
Old Jul 29, 2011 | 12:20 PM
Rodolfo's Avatar
That is the spirit, just try it, in a straight line the first time, nothing will happen. And tell us how it went.
That is what syncronized transmission do, they syncronize the speed of the motor with the car speed, to make the jerk so slight that it doesnt upset the car.
Of course if you are mid corner, and you want to go from 4th to 2nd, then you should heel and toe a bit, but this just aplies if you want to do something like that, from 4th to 2nd, or from 5th to 3rd, and in this last case not as much.
So yes, I will give you that, in midcorner with heavy braking with need to downshift, heel and toe will come into play.
But in straight line bracking, theres is absolutely no need for it.
Old Jul 29, 2011 | 12:24 PM
i am not sure if its wise to shift from 4th to 2nd in mid-corner..
i personally like to be in the proper gear before entering the turn
Old Jul 29, 2011 | 12:28 PM
marsfire's Avatar
marsfire is infamous around these parts
for heel-toeing, brake first, then rev and downshift into the proper gear.
for the 1st-2nd shift, i usually shift around 2-3k. but that's for normal driving. if you wanna push it a bit, you can shift anywhere you want before redline
