Low fuel Warning
Old Nov 4, 2011 | 12:59 PM
ksdprasad's Avatar
ksdprasad is infamous around these parts
Low fuel Warning
noticed whenever i get a low fuel light, if i add 3-5 gallons, the warning still stays on and the fuel gauge does not rise. However if i fill it up, this will reset the warning and gauge back to normal... any ideas if this is normal?
Old Nov 4, 2011 | 01:06 PM
OKB's Avatar
OKB
OKB is infamous around these parts
you have to add alot or it wont reset the warning
Old Nov 4, 2011 | 01:12 PM
goncookoo's Avatar
goncookoo is infamous around these parts
SWEET! I thought I was the only one!
I feel so much better that Im wasnt just imagining things.
Phew!
Old Nov 4, 2011 | 02:21 PM
FlaHeel's Avatar
Had the same issue, added small amount of fuel to get me to usual supply but light never went off until I finished filling up.
Old Nov 4, 2011 | 03:07 PM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
If anything that seems wrong with the car, it's normal. Just like the brake squeal, so they said at pcna.
Old Nov 5, 2011 | 04:58 AM
jhbrennan's Avatar
You guys need to read your owner's manual -
If a small quantity of fuel is added to a nearly emp- ty fuel tank, the fuel gage cannot measure the add- ed fuel accurately. The „remaining range“ readout will also be incorrect.
Old Nov 5, 2011 | 07:17 AM
FlaHeel's Avatar
With the users manual being the size that it is unless there is something that is really bugging me then I don't bother. I believe what jhbrennan is saying though.
Old Nov 5, 2011 | 07:37 AM
jhbrennan's Avatar
I use a pdf version so I don't have to thumb through all the pages. You can join renntech.org and download.
Old Nov 5, 2011 | 03:04 PM
robster1974's Avatar
robster1974 is infamous around these parts
Agree the PDF version is more user friendly. Read it on the plane via iPad etc next time u have time to kill.
Old Nov 7, 2011 | 02:30 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
The fancy fuel system, like the oil level system, require you use it in a certain way. Splash and go doesn't work. Sure you have 2 more gallons in the tank, but the computers don't register it. When you gas up, fill it all the way up (the car may use that as a way to reset the max level each time for all I know).
Old Dec 21, 2011 | 04:06 PM
Bigthistle's Avatar
Bigthistle is infamous around these partsBigthistle is infamous around these parts
Question Kangaroo...
OK - was running low (driving from ATL to FLL) and splashed 4 gallons of gas at Flash Foods (couldn't find a brand name to fill up), warning didn't change as suggested in prior posts.
20 miles later found BP and filled up - took 13 gallons.
300 miles later, showing quarter of tank remaining, starts to kangaroo - fuel starvation, no warning lights. Back off gas, gently drive 9 miles off the turnpike and BP again - BUT only 13.5 gallons to fill up (as in 3 gallons left....). Fill up, gently drive a few miles and kangaroo goes away.
What's going on? Shouldn't be running out on quarter tank left - does gauge need recalibration?
Rguy
Apr 12, 2020 11:11 PM
COBB Tuning
Mar 29, 2016 09:26 PM
HotRod
Sep 10, 2015 07:17 PM
