Transmission Fluid. Drain and fill.
Old Nov 12, 2011 | 06:39 PM
jtg077's Avatar
jtg077 is a jewel in the roughjtg077 is a jewel in the roughjtg077 is a jewel in the roughjtg077 is a jewel in the rough
I am trying to change the transmission fluid in my 2007 C2S.
I have seen a few DIY pics that led me to believe it's not too difficult to drain transmission fluid and put in new fluid.
I am confused... All the DIY pics I see online look like the plugs for transmission are similar to the OIL drain plug. However I can't find any plugs like that on the transmission.
Are these the correct plugs? What kind of tool do I uses for these.
Is this difficult?
I am thinking this is the drain plug. It's on the bottom of the transmission.
So would this be the fill plug? It's about halfway up on the transmission (passenger side). I am confused because it looked like other DIY's online showed the fill plug to be on drivers side.
I also noticed another thing, up higher by the axle (passenger side). What is this plug for?
Old Nov 12, 2011 | 06:50 PM
tcouture's Avatar
tcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to beholdtcouture is a splendid one to behold
Manual or Tiptronic?
On the manual, the transmission shares fluid with the brake system. There is a bleed nipple on the transmission and you just bleed like you would do with the calipers.
On Tip, I would't know. Maybe ask on RennTech?
T.
Old Nov 12, 2011 | 06:55 PM
jtg077's Avatar
T.
Mine is a manual transmission. I think you're thinking of clutch fluid?
I am talking about the manualy transmission fluid.
Old Nov 13, 2011 | 09:05 AM
b2sc's Avatar
b2sc is infamous around these parts
In my experience with MTs (but not 911s), there will typically be 3 plugs for the tranismission fluid drain/fill procedure.
The bottom is obviously the drain plug, the top is the fill plug where oil is entered into the tranny case and the middle plug is a "full" plug. With this plug removed, fill the transmission with fluid from the top orifice until oil your new fluid comes out of this outlet. It's full. Reinsall the plugs and you're all set.
Old Nov 13, 2011 | 12:38 PM
tcouture's Avatar
Oupsssss! You are ABSOLUTELY right, I was thinking about the clutch slave cylinder.
b2sc is correct, the middle is the "full plug".
Sorry for the brain fart,
T.
P.S.: Don't drink and post!
Old Nov 13, 2011 | 06:08 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
remember to remove the fill plugs before removing the drain plug.
Old Nov 14, 2011 | 09:17 AM
jtg077's Avatar
Does anyone know what size plug this is? Just trying to figure out if I have the correct tools.
ECS Tuning - BMW
Sep 23, 2015 01:31 PM
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
