Correct Wheel Offset, HELP PLEASE!
Old May 12, 2005 | 08:24 PM
bpanos's Avatar
bpanos is a jewel in the roughbpanos is a jewel in the roughbpanos is a jewel in the roughbpanos is a jewel in the rough
Can someone please tell me what wheel offset I should be using to accomodate a 305/30/19 Michelin PS2 tire on my 997S without rubbing issues? Will a et55 work for the rear or do I need to go with et58 or et60? Wheel is 19x11. TIA.
Old May 12, 2005 | 08:34 PM
RENNWORX GT3's Avatar
RENNWORX GT3 is infamous around these partsRENNWORX GT3 is infamous around these parts
Is the car lowered or will you be lowering it?
19X11 +58MM 305/30/19 is a good application
without rubbing .
It is a good idea to roll the fenders so as not to have any reasons to rub.
I have done a 997 with 19x11 +50mm stock ride height no rubbing.
19x11.5 +56mm 305/30/19 works as well but rolling the fenders needs to be done.
Sounds like a great car good luck!
Old May 12, 2005 | 09:12 PM
bpanos's Avatar
Thanks! Yes, car is lowered and I do not want an extreme fit either. I actually prefer the tires to be tucked in just a little. I will probably go with et58. I also noticed that you did a 19x11 et50..... is that correct? I would think that would stick out beyond the fender..... unless you stayed with a 295 tire.
Old May 12, 2005 | 10:21 PM
20C4S's Avatar
does PS2 come in 305/30-19. if they do that's odd.
Old May 12, 2005 | 11:22 PM
bpanos's Avatar
PS2 305/30/19 will be released in July for the 997C4S. Part no. 86050
Old May 12, 2005 | 11:37 PM
20C4S's Avatar
cool. special for Porsche then.
Old May 13, 2005 | 12:55 PM
Yes the 19x11 +50mm used the 295!
Good to know about the 305 release date thanks for the information.
Old May 13, 2005 | 06:50 PM
bpanos's Avatar
the wheels I have on order are 19x11 et55. Will this offset work with a 305/30 tire?
Old May 13, 2005 | 09:23 PM
It sounds to me like the application will be close to the fender lip @55mm with the 305. The 295 measures out to 26.0 O.D. and the 305 comes in at 26.2 so it is a little taller. The thing you need to consider is that different tires fit different even if they are the same size. The Michelins are big and blocky in the side wall and do not pull in but stand strait and are more likely to rub than say a Yokohama or Continental.
I just did a stock height 997 today with 19x11 @ 57mm and Michelin and I would say a 305 on a lowered car would be close to the inner fender no problem if you roll the fender but you said you wanted them to tuck and I think you will end up with it being at the edge of the inner fender lip.
Old May 13, 2005 | 10:21 PM
alin330's Avatar
alin330 is infamous around these parts
anyone know what is the Stock 997S wheel offset? front and back.
Old May 13, 2005 | 10:27 PM
bpanos's Avatar
front et57 and rear et67
Old May 13, 2005 | 11:47 PM
alin330's Avatar
Thanks bpanos
Old May 14, 2005 | 08:58 AM
It should be noted that the stock front wheel is a 19x8 @ 57mm
and most aftermarket parts are 19x8.5.
FYI
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
