coilover bilstein noise / question....
Old May 8, 2013 | 01:30 PM
  #31
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Originally Posted by keninirvine
I'm tempted to add a lock nut just to be sure it doesn't back off.
Ken, the strut already has an aircraft nut in your pic. It won't back out.
Old May 8, 2013 | 01:45 PM
  #32
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
Originally Posted by ryem3
Not sure on the 911 exactly, but it should be accessible. You can't just turn the nut, you need to hold the strut rod with a hex wrench. Bilstein should provide a torque setting for the bolt. From all the pics, this should already be an aircraft nut.
Correct, the nut is easily accessible. I used a box-end offset wrench (22mm) to clear the opening in the top of the fender. It is an aircraft nut. I left a message a few weeks ago with Bilstein regarding the recommended torque but they never responded. Actually, since that bearing and top mount hardware is from the original factory strut, the torque should be the same as the factory struts. Anybody know what that is?
Old May 8, 2013 | 05:34 PM
  #33
ryem3's Avatar
I couldn't find an instruction manual. You might try calling Ground Control in CA. They are suspension experts and could provide some guidance.
Old Jun 13, 2013 | 12:25 PM
  #34
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
We've now replaced the top bearings, front trailing arms, fore/aft, and inner tie rods.
Rattle /clunk persists.
For 4 1/2 years this has not been an issue on this car.......more than frustrating right now.
Old Jun 26, 2013 | 06:55 PM
  #35
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
I had the same issue, my mechanic installed thrust washers and the problem went away
Feb 24, 2016 01:10 PM
maroli
Sep 15, 2015 07:07 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
AJUSA.com
991 Vendor Classifieds
Sep 9, 2015 12:47 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
