battery tender question
Old Mar 3, 2012 | 02:46 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I put a set of pig tails on the battery so I can plug in a battery tender when the car is not being used. My question is , with the hood only down to the first latch, because the wire runs into the trunk , I noticed the trunk light is on. Will this go off after a certain peroid of time? How long? If not how do you guys run the wire in and close the trunK? Thanks
PS/ thanks for your time guys, some of us here with our new cars are just trying to figure some things out.
Old Mar 3, 2012 | 04:06 PM
cerbomark's Avatar
I found a better way. I came out the top by the winshield so I can close the trunk completely...
Old Mar 3, 2012 | 04:14 PM
jhbrennan's Avatar
It will go off in about 2 hours:
If the ignition key is removed, loads which are
switched on or are in standby mode (such as the
luggage compartment light, interior light and
radio) are automatically switched off after approx.
2 hours.
It will go off a lot faster (10 to 20 minutes) if you lock the car with the remote.
Old Mar 3, 2012 | 04:18 PM
cerbomark's Avatar
good to know, thanks
Old Mar 3, 2012 | 04:21 PM
PSPorsche's Avatar
PSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond repute
I was able to close the trunk completely. Run the wire along the rubber seal that outlines the trunk opening. The wire can be stuffed under the rubber, just as the plastic trim fits under the rubber seal. Then take the wire out the front about a foot of center. The trunk closes completely and the wire does not pinch or scuff any paint.
Old Mar 4, 2012 | 04:36 AM
seapar's Avatar
seapar is a glorious beacon of lightseapar is a glorious beacon of lightseapar is a glorious beacon of lightseapar is a glorious beacon of lightseapar is a glorious beacon of lightseapar is a glorious beacon of light
I bring out the wire by the windscreen . I also was shown the front latch with a screwdriver can push on the latch and then can set the front hood down but not locked ( gap of two inches) or so. You can reset by just releasing the front hood latch by the driver's seat when you bring back to normal.amybody else heard of this?
Old Mar 4, 2012 | 09:29 AM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
I use the cigarette lighter option and that works great. Open passenger side window run it through there and no worries. Never had a problem and charges very well.
Old Mar 4, 2012 | 09:36 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Theres a rubber trim towards the bottom of the pass door you will see a hole stretch the rubber seal and send the wire threw it and you can close the door perfectly without crimping the wire. Hope i explained that well
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
RallyBird
Oct 7, 2015 01:20 PM
away
Sep 4, 2015 12:30 PM
