problem with tire pressure sensor.
Old Mar 20, 2012 | 10:09 PM
metzkaro's Avatar
metzkaro is infamous around these parts
I was driving around my 2007 Carrera S like i normally due and randomly my tire pressure sensor decided to go off. I took it to my tire place and had them check the pressure but it was fine. what should i do to get rid of this?
Old Mar 20, 2012 | 10:13 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
I would check the batteries. They are probably bad. They are not cheap either. I'm running Nitrogen in my tires to keep the pressure more consistent, which I won't really see until summer when the temps can go up a lot with hot pavement and ambient temps.
Old Mar 21, 2012 | 12:40 AM
p997c's Avatar
p997c is infamous around these partsp997c is infamous around these parts
you may want to check TPMS. probably out of battery.
Old Mar 21, 2012 | 03:23 AM
metzkaro's Avatar
where can i buy these batteries? and how can i have them changed?
Old Mar 21, 2012 | 06:08 AM
jhbrennan's Avatar
Batteries are not replaceable - you have to replace entire TPM sending unit in the wheel. Dealer can use one of his electronic tools to tell you if it's a battery problem. If one battery is bad it probably won't be long before the others go so you might want to think about replacing all 4 sensors at the same time.
http://www.suncoastporsche.com/Order...-Sarasota.aspx
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
