Parking brake in garage?
Old Mar 26, 2012 | 07:04 AM
kes7u's Avatar
kes7u is infamous around these parts
I am one who has never used the parking brake in my garage. I leave the car in 1st gear, turn it off, and the car doesn't move. I went out to the garage this morning, to find that the car was REALLY close to the garage door. I couldn't believe that I had only left myself what appeared to be an inch between the rear bumper and garage door. I went closer, and realized that the metal slat on the garage door was up against the bumperettes!! I then realized that I had forgotten to leave the car in gear, and it had rolled back into the door. I pushed the car forward and applied the parking brake. TINY, un-noticeable dents in the bumperettes from the metal slat. Better that then anywhere else I suppose.
Lesson learned? Should I use the parking brake from now on, or simply remember to leave the car in gear??
Kevin
Old Mar 26, 2012 | 07:44 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
I would say leave it in gear if it was below Zero in the garage so the calipers wouldnt freeze on the rotors but why not just pull the E-break? Pull it up enough i never yank the ebrake to the last 2 clicks unless its parked on a hill.
Old Mar 26, 2012 | 07:49 AM
mjsporsche's Avatar
mjsporsche is a jewel in the roughmjsporsche is a jewel in the roughmjsporsche is a jewel in the roughmjsporsche is a jewel in the rough
I use the parking brake in the garage throughout the year. Gently applied...not to the last click.
Old Mar 26, 2012 | 08:17 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Always apply PB and put the car in gear out of habit, in or out of the garage.
Old Mar 26, 2012 | 08:29 AM
frontside720's Avatar
frontside720 is infamous around these partsfrontside720 is infamous around these parts
I use both but don't pull the brake to hard.
I'm in Toronto and my garage isn't heated but it's never below zero in there.
Old Mar 26, 2012 | 08:53 AM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
I don't think the e-brake has anything to do with the calipers and rotors.
I seldom use the e-brake in the garage, but use it elsewhere when parked on any incline.
Old Mar 26, 2012 | 09:22 AM
last911's Avatar
last911 has a spectacular aura aboutlast911 has a spectacular aura about
The hand brake / parking brake is a small drum brake contained in the center hub of the rear brake discs. It has a set of small shoe brake pads within the hub. It has absolutely nothing to do with the caliper as it is a completely separate system.
Old Mar 26, 2012 | 11:39 AM
Strange on a previous car of mine i had pulled the ebrake in the dead of winter and the caliper was stuck and didnt release for while maybe the cable was friged up. Sorry for the false info.
Old Mar 26, 2012 | 11:54 AM
modlin's Avatar
modlin is infamous around these parts
gear in
pb on unless came off driving in the rain or washed the car
m.
Old Mar 26, 2012 | 01:15 PM
b2sc's Avatar
b2sc is infamous around these parts
I for one rarely use the PB when in my garage. I drive into the garage in geaar, and shut it down in gear. (famous last words until MY car rolls into the door, right?)
Old Mar 26, 2012 | 09:31 PM
ecostellodo's Avatar
ecostellodo is infamous around these parts
I always put the car in gear and use the parking brake. And on a hill, if the curb is low enough, I turn the wheels into it.
Old Mar 26, 2012 | 10:22 PM
DoninDEN's Avatar
DoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond repute
I always leave it in gear when I park. I don't trust the PB. I don't understand why there even is a parking brake...
Old Mar 26, 2012 | 11:57 PM
My car rolled back when i pulled it halfway at the gas pump lucky i wasent filling yet yikes!!
Old Mar 27, 2012 | 12:53 AM
home7271's Avatar
home7271 is infamous around these parts
Years ago, I had this happened to me. I had just parked my car and the space was on a not so gentle slope. Pulled the parking brake, got out, locked the car and started walking away. A moment later, my car's alarm went off. I turned around and to my amazement, my car actually rolled back about a full length of the car. It only stopped because the area behind the car was pretty level.
This was not on a curb side where you could turn the wheel and wedge it against the curb.
Lucky it did not hit any thing. The alarm went off because it had some kind of a level sensor. If the alarm did not work, I would have continued to walk away and never knew my car was in the middle of the parking lot!
I was shocked! I thought I pulled the parking brake pretty hard. After that, I would never trust the parking brake alone. Always put it in gear!
Mike
Old Mar 27, 2012 | 10:56 AM
FlaHeel's Avatar
Thumbs up
Very good habit to get into!
